I installed a 350/290hp crate motor bout a year ago. Alll of a sudden I get poor performance. I did a compression test. All 8 cyl. read 125 psi. This seems low to me. Any ideas?
Compression sounds OK. I would look at timing,points, fuel pressure/filter, if you have a Catalytic converter it may be stopped up, might need a carb adjustment, if you have a Holley look at the power valve. How did the plugs look when you pulled them? What exactly do you mean by poor performance?
I installed a performer manifold, edelbock 750 carb, summit distrib, msd ignition and headers. Timing set @10deg. vac.is 13hg. It just runs rough has hesitation on take off. sometimes poping through carb.
I adjusted valves, set timing which i'm guessing at. Summit told me to set timing at 10 degrees. I found the intake gasket was leaking, changed that. Unplugged all vac. lines capped them off reading did not improve. This has me baffled.
