I had the same problem on the 76', so I took out the dash, and it was basically one of the more horrible experiences with that car, lol. The switch wasn't bad though, it was the wires. They were all dried and cracked, so I cut the problem area, and spliced in new wire, for as far as I could reach. Someday, I've got to just replace the harness all together....
but yeah, to your problem, for me, it was just bad wires, rubbing and grounding, etc.
Ahhh!! Lol! Thanks. I'm thinking about pulling the number's matching motor and saving it. If I do that then I'm going with a TPI motor and new wiring harness. This might push me over the edge to go for it and tackle a new harness project.
Your problem is likely to be one of two things. 1.) someone (previous owner, etc.) has changed out all of the bulbs and put the wrong bulbs back in (lower wattage than specified); 2.) the rheostat in the light switch is worn out. My guess is that #2 is most likely the problem. If you turn the rheostat from "OFF" up through its full range, and it reaches maximum [although weak] brightness well before you reach the end of its travel, the stat is defective. If is gradually goes from dim to max brightness near the end of the rotary travel, its not the switch.
I was thinking the same thing. I'm going to get a new switch and replace all the bulbs. If that doesn't do it then I'll have to dig into the wiring (my least favorite project). Thanks you!
Dan
If you really want to put this to bed, you have to pull the speedo / tach cluster and the gauge cluster and ditch the flex printed circuit and connector and hard wire, creating a new "lead away" wire loom with strain relief. I was able to modify the bulb sockets so wire could be soldered to them, and still retain the twist lock function. I left a "S" of extra wire between each socket for removal. It turned out very nice.
My dash lights are plenty bright enough now, using whichever bulb was the brightest (168 or 192? ....can't recall right now) and UPSIZING the black ground and gray instrument light circuit wire. I grounded both my gauge clusters to a new frame ground spot and did not use the stock ground wire in the harness. I also ran the upsized gray all the way to the head light switch reostat. Brake, brights and turn indicators are ofcourse brighter as well.
I am totally pleased. Worth all the effort....The connector plugging into the recess and making contact of the printed circuit "fingers" just was not a long term solution....it was a cost solution.
guys you are missing the obvious......clean up the ground areas especially where the metal dash is grounded....you will be surprised how much of a difference it makes
______where is the instrument cluster lighting circuit grounded at?????????
