How Fast?
Old Feb 21, 2008 | 01:20 PM
Ironcross's Avatar
Ironcross
Default How Fast?
A Vette traveling at 5500 RPM`s in 4th driving into a 4.11 gear with rear tires of 235-60R-15`s would be going how fast? No its not a trick, I just wanterd to know the approximate speed it was traveling. Any idea? 120, 125, I dont have a clue.
Old Feb 21, 2008 | 01:36 PM
Scott Marzahl's Avatar
Scott Marzahl
Here is a calculator, but you need some more numbers to calculate it, Transmission gear ratio and tire diameter.
http://wahiduddin.net/calc/calc_speed_rpm.htm
Old Feb 21, 2008 | 01:40 PM
blckslvr79's Avatar
blckslvr79
Stock 4 speed should be a 1:1 ratio in fourth.
235/60/15 is 26.1 inches tall
Old Feb 21, 2008 | 01:42 PM
blckslvr79's Avatar
blckslvr79
207.8 mph
That was fun! any more????
no wait! that can't be right?? Well that's what that link says???
LOL-trick website-it asks for "Tire RADIUS"-not diameter!
Old Feb 21, 2008 | 01:43 PM
yel76low's Avatar
yel76low
104mph
Old Feb 21, 2008 | 01:47 PM
blckslvr79's Avatar
blckslvr79
Originally Posted by blckslvr79
207.8 mph
104mph
Try this link..
http://richmondgear.com/streetcalculators.html
Old Feb 21, 2008 | 01:52 PM
DvBoard's Avatar
DvBoard
Originally Posted by yel76low
104mph
This is closer i think.
Old Feb 21, 2008 | 01:54 PM
blckslvr79's Avatar
blckslvr79
LOL-yup.
Gotta read the fine print! My bad.
Most of these calculators ask for tire diameter. I input it too quiclkly without reading.
Old Feb 21, 2008 | 02:31 PM
Ironcross's Avatar
Ironcross
Default Thanks Gentlemen,
I didn`t have a clue but I guess the buck O fore [104} sounds about right.
The trans is a M21 but high is 1-1 anyway right?
This was not a 1/4 time, just stood on it for a moment ot two.
Old Feb 21, 2008 | 03:41 PM
Matt Gruber's Avatar
Matt Gruber
that's exactly the set up on my 61.
47-1st
104-4th
Old Feb 21, 2008 | 04:40 PM
Glensgages's Avatar
Glensgages
'assuming' the tires are 27"-tall (a guesstimate? ):
5500 x .006 x 1/2 TH (Tire Height, or 13.5 ) div/by 4.11 = 108.39 MPH +/-
Old Feb 21, 2008 | 04:51 PM
Gordonm's Avatar
Gordonm
104 mph.
All the stock muncies were a 1:1 4th gear.
Old Feb 21, 2008 | 11:10 PM
jim2527's Avatar
jim2527
I redlined my C5 in 3rd (1:1)(A4) with a 2.73 rear....once
Old Feb 22, 2008 | 12:41 AM
Z-man's Avatar
Z-man
I'll go with 104 mph...
http://www.keislerauto.com/tools/gm_analyzer_5sp.html
Old Feb 22, 2008 | 01:18 AM
gofastvette's Avatar
gofastvette
one formula is 104 and the other is 108,,,tire growth maybe..
Old Feb 22, 2008 | 12:53 PM
KevinK's Avatar
KevinK
Hmmm.....so, now I know. My speedo is off by about......30 miles per hour. Good GOD!!! No wonder it felt...."Fast", lol.
And on another good note, I smoked a NEW Rustang GT the other day. God, that felt so good. A little sign that I am getting some things doen with this car.
Old Feb 22, 2008 | 02:07 PM
gkull's Avatar
gkull
It just really shows you how non OD trannys really suck. If Ironcross had a TKO 600 with a .64 OD he would be doing nearly 160 mph at the same 5500 rpm. I have driven my 434 ci vette for about 20 miles at over 6000 rpm in 5th gear and 4.11 rear end. It gets my speed fix in for a few days
To How Fast?
Old Feb 23, 2008 | 12:47 AM
enkeivette's Avatar
enkeivette
In 6th gear at 6500rpm with my 25.5" tire and 3.55 gears I would be at 277mph. So I guess my car isn't gear limited.
And with 600hp on tap my car probably wouldn't be hp limited.
So the remaining factor would be the car itself. I'm sure it would catch air and/ or destroy itself before it hit top speed. Can you imagine having wheel bearing failure crawling past 160mph? --->
Old Feb 23, 2008 | 03:50 AM
murraybs's Avatar
murraybs
I'd say that you'd be HP limited around 180ish. Coefficient of Drag for the C3 is MISERABLE, despite the sleek look (it's the windshield's fault).
Old Feb 23, 2008 | 07:51 AM
jim2527's Avatar
jim2527
With the OD A4 in my old C5 it would hit 182 in 3rd gear but turn 1200 rpm and get 30+mpg in 4th.
