Hooker Sidepipe Questions
Old Feb 21, 2008 | 04:18 PM
LannyL81's Avatar
LannyL81
Default Hooker Sidepipe Questions
Have installed the Hooker Sidepipes onto my '81 however, the passenger door hits the sidetube when opening the door. Am I going to have to bend the headers down or is there another way to fix this?
Thanks,
LannyL81
Old Feb 21, 2008 | 04:24 PM
Durango_Boy's Avatar
Durango_Boy
Thanks,
LannyL81
Post a pic...my Hooker side mount headers are nowhere near that high...I'm thinking they may be mounted incorrectly.
Old Feb 21, 2008 | 05:03 PM
blunblk68's Avatar
blunblk68
mine did the same on the drivers side, with the collector pinch bolt loose i just set my foot on the end of the pipe and used a very little pressure to bend it down and no more rubbing!! I think sometimes in transportation of the pipes the tabs get a little bent.
Old Feb 21, 2008 | 09:58 PM
DZRick's Avatar
DZRick
Exactly what I had to do.
Old Feb 21, 2008 | 10:07 PM
AB73's Avatar
AB73
Default Same here
Me three, doesn't need to be bent, just an alighnment issue easily adjusted.
Old Feb 21, 2008 | 11:53 PM
sperkins's Avatar
sperkins
Both sets I've installed, I've had to drill a small hole in the frame to move the tab down far enough to make the tubes straight.
Old Feb 22, 2008 | 02:34 PM
69vettester's Avatar
69vettester
Common problem ..ditto the Just step on it with a little foot pressure..the tabs will bend and no hit no mo.
Old Feb 22, 2008 | 05:59 PM
LannyL81's Avatar
LannyL81
When "tabs" are referred to....what do you guys mean?
I do not have the pinch bolt in the tubes.....they are such a tight fit and the bolt that came with is the wrong thread pitch.
Old Feb 22, 2008 | 10:14 PM
Glassbowtie77's Avatar
Glassbowtie77
Mine did it on both sides, and that's how I solved the problem.
Old Feb 26, 2008 | 07:21 AM
LannyL81's Avatar
LannyL81
Just want to find out about those "tabs"
Old Feb 26, 2008 | 09:43 AM
bashcraft's Avatar
bashcraft
Mine are very close to the doors. I'm thinking yours are mounted incorrectly.
Old Feb 26, 2008 | 09:52 AM
Durango_Boy
Mine aren't scraping the ground or anything but the doors have never hit them and I have at least a full finger's width between the two, on both sides.
To Hooker Sidepipe Questions
