T56 dimensions
Old Feb 21, 2008 | 10:24 PM
techsol's Avatar
techsol
Default T56 dimensions
Can anyone give me the correct spec's of some T56 questions?
Case dimensions, shifter dim, case length dim and bellhousing dim's for the different available t56 trannys from f body's and other available sources. I've found a couple from fortes, 5 speed and tremec and they don't match the f body 93-97 tranny I have.
Trying to get an idea how close my shifter breakout is going to be with my C3. I don't want to mod my console.
Trying to do the what if before I get too deep into the project, in case I need other parts.
Old Feb 21, 2008 | 11:10 PM
72LS1Vette's Avatar
72LS1Vette
This link may be of some help.
http://www.sallee-chevrolet.com/BorgWarner/t56pics.cfm
Rick B.
Old Feb 22, 2008 | 12:26 AM
dahctor's Avatar
dahctor
Here are some links that might help.
http://www.5speedtransmissions.com/6_speed.html
http://www.drivetrain.com/gmt56inst.html
http://forums.corvetteforum.com/show...ht=t56+console
Old Feb 22, 2008 | 08:47 AM
techsol's Avatar
techsol
Thanks guys I'm going to check them out tonight!!!!
Old Mar 3, 2011 | 12:47 PM
Z06-GT3's Avatar
Z06-GT3
Default Dimensions of T56 (Z06)
Z06 2007 - T56
Hi
Can anyone help with dimensions of the T56 or a set of drawings that show the details.
Need the dimensions and details as shown in the sketch below
thanks
Old Mar 3, 2011 | 06:12 PM
442olds's Avatar
442olds
HTTPS://picasaweb.google.com/438vett...missionRebuild
Sorry the link button doesn't work on this stupid win 7 phone.
Anyway there is a picture of where a 93-97 t56 shifter will poke thru your floor board. You will need to buy or make an offset shifter handle to make it work with your factory counsel. The trans is the same length as a 700r4 from the front off the bellhousing to the end of the tail shaft but its slightly longer than the th350.
Old Mar 3, 2011 | 06:51 PM
72LS1Vette's Avatar
72LS1Vette
Originally Posted by Z06-GT3
Z06 2007 - T56
Hi
thanks
The link that I posted 3 YEARS AGO has that information.
Rick B.
Old Mar 5, 2011 | 09:28 AM
Z06-GT3's Avatar
Z06-GT3
I had a look at those links.
I can not see how to get the dimensions I need from those diagrams.
Am I missing something ?
To T56 dimensions
