Heim jointed TA....New way?
Old Feb 22, 2008 | 09:21 PM
73339's Avatar
73339
Default Heim jointed TA....New way?
Why not just screw a regular heim into a thread section that is welded on the TA
they would even be adjustable to make sure everything is lined up real good
Old Feb 22, 2008 | 09:23 PM
Durango_Boy's Avatar
Durango_Boy
From the top that looks like a path leading from a gazebo to a swimming pool with black water in it.
Cool idea though...care to elaborate further?
Old Feb 22, 2008 | 09:26 PM
73339's Avatar
73339
Instead of welding the johnny joint on you could just weld a threaded sleeve to the trailing arm It would be like a link in a 3 or 4 link suspension
Old Feb 22, 2008 | 09:29 PM
Durango_Boy
Isn't there a kit that does something similar to that, but that's a bolt on? I seem to remember a guy at the GM service center a few years back telling me he and a buddy put one on their car, in effect taking the load off of the half shaft as the upper link and adding a new link.
Old Feb 22, 2008 | 09:31 PM
73339's Avatar
73339
This would go where the front of the t-arm bolts to the frame
Your talking about a 5-link
Old Feb 22, 2008 | 09:49 PM
Durango_Boy
How easy do you think fabbing that up and welding it in would be? What kind of materials would be needed?
Old Feb 22, 2008 | 09:53 PM
palamesa's Avatar
palamesa
Welcome back yellow73sb....I've been following your racing efforts.....nice job
Old Feb 22, 2008 | 10:45 PM
Artsvette73's Avatar
Artsvette73
Strength comes to mind.The lack of to be exact. Just look at your diagram and you can see where it will break. One. where it will thread into the trailing arm. Two. the outer sphier of the joint. The heim joints thread size, and hole size are matched. You would have to put a pretty big joint back there to take any abuse. The hole size in the frame would have to be increased. I wouldn't be comfortable doing any high speed turns.
Old Feb 22, 2008 | 11:13 PM
69autoXr's Avatar
69autoXr
Yes it can be done this way...cut the bushing end of the trailing arm off and weld in a threaded block.
Old Feb 22, 2008 | 11:50 PM
73339's Avatar
73339
I don't think theres much stress on it cornering though
I probably won't do it but I was just thinking
Old Feb 23, 2008 | 02:37 AM
rpoL98's Avatar
rpoL98
Herb Adams used to have a spherical ball bushing/joint kit (same type as HEIM joint) that you welded into the factory trailing arm. I bought one and welded it in, but ended up not using it. The assembly was pretty straight-forward. The spherical ball was greasable and I couldn't figure out the best way to provide access to the zerk. Then Moroso became the reseller for the Herb Adams stuff. not sure if they still sell it.
To Heim jointed TA....New way?
