Radiator & Core Support Replacement
I've got a new support from a '76, not sure early or late, that will need new feet and a new radiator on the way. I want to get started and get everything out so I when the radiator gets here I'm ready to put it back in.
Here is the plan:
Remove the hood.
Drain the radiator
Remove the fan
Pull the transmission lines
Pull the hoses
Remove the 6 side bolts
Remove the bottom 2 bolts
Pull the radiator, support and shroud as a single unit.
Then I'll remove radiator and shroud from support and compare the bad support with '76 support.
I've got a couple of questions:
1 - Am I missing anything?
2 - Do I need to provide additional support for the nose? My front bumper and retainer are off, but I put the bolts back in to the frame extensions (through the front of the body) to keep the nose aligned. Is that enough? Should I reinstall the '75 supports 6 side bolts until I'm ready to install the new parts? Do I need to reinstall all 8 bolts?
3 - Are there any other lines (vacuum, wiring, etc.) that run through the support I need to worry about?
Blue painters tape your fender and nose!!!! Fender support should be good..juts dont leave like that for weeks.
I measured between the two lower u shaped support brackets and the distance is the same on both my supports.
This didn't go too bad. We got the hood off, radiator drained and radiator/shroud/support out in one piece in about 2 hours.
then we poped the pulleys and harmonic balancer. Need to replace the timing chain cover seals and balancer seal before I put this all back together.
