ARGH!!!! BELT!!! HELP!!!
http://shop.emotorstore.com/estore/td_techtips_vb.asp http://www.thirskauto.net/Fan_Belts.html</A> http://www.industrialtechnology.co.u...apr/gates.html <A HREF="http://www.maintenanceresources.com/ReferenceLibrary/V-Belts/Simple.htm" TARGET="_blank">http://www.maintenanceresources.com/ReferenceLibrary/V-Belts/Simple.htm
I had the same problem once also. Turned out to be a slight dent in the pulley was setting up an oscillation in the belt and with the long-run of the belt it was enough to cause it to pitch everytime I wound it out a bit.
[Modified by gerry72, 11:38 AM 12/5/2001]
A couple of things.
1. The older vettes had a deep groove alt. pulley. I don't know if this was
carried to the newer models. Is your alt. original or has a it been replaced.?
Meaning, maybe your deep groove pulley went with the old one.
Also the pulley was not the "tin" type, it looks like a machined part.
2. I had a '69 Camero 350 that would do the exact same thing.
The problem was the type of belt I was using. If I put on a Gates, I could roll it at the first sign of high revs.
Someone suggested I use a belt with notches in it. I found one with
notches on the "V" side, and put it on. It could go to 7200 rpm without
a problem. (Sorry, too many years ago to remember the make).
On the vette now, I am using a belt with the notches on the top.
See picture below. Hope some of this helps.
Barry
I think you are right. I couldn't remember what it was.
It's been on there for several years. It's seen 6500 rpm many times with
no problems. The old original Goodyear never had a problem either.
I think the alt. pulley makes all the difference. Given alignment and everything
else is fine.
Barry
They also list, from March, a polished aluminum kit for 71 - 82 Corvettes with V-Belts. It includes a 3 groove crank, 2 groove water pump and an alternator pulley w/cap for $212.99. It's part number 655-5070.
Hope this helps a little. :seeya
Hi. I was reading your comments and viewed the photo of the engine on Barry's car. Those "Top Cog" belts are made by Dayco. I use these belts on both of my Corvettes. ('75 Coupe L48 and '70 Convertable L46) Our friends use these Dayco Top Cog belts on their cars as well with good results.
David
Welcome to the Forum. Thanks for keeping us honest on the belt.
I hope you enjoy the Forum. Most of us have lots of past/present experiences
(good and bad), I hope you will share some of yours as well.
Barry
You mentioned that you didn't want a $4.00 belt causing you to ruin your engine. Remember that you get what you pay for. A cheap belt will not have the high speed stability that a good belt will have. They do not have as much fabric cord built into the belt and this is what gives the belt strength. Also belt tension is very important. In the middle of the span between two pulleys you should only be able to depress the belt about 1/4 of an inch. They do make a gauge for checking proper belt tension. I think they run about $10 dollars. I run Dayco "Top Cog" belts on our two corvettes, 75 coupe L-48 & 70 conv. L46. With good belts, proper pulley alignment & proper tension, you should be able to run 7,000 rpm without problems.One other thing, the shorter the belt you can run, the better. Good Luck!!!!!
David
"I get no kicks from champagne..mere alcohol doesn't thrill me at all..so tell me why should it be true..that I get a BELT :mad outta you!!" :jester
