Restoration
Old Feb 23, 2008 | 11:40 PM
Doug Maitlen's Avatar
Doug Maitlen
Default Restoration
How much would a frame up restoration cost on a 1979 L-48?
Doug
Old Feb 23, 2008 | 11:51 PM
'75's Avatar
'75
That all depends on if you do it yourself or have a shop do it. Could go any where from 10g to 40g
Durango_Boy's Avatar
Durango_Boy
Doug
Depends a lot on how much you have to replace, how much you replace with new instead of used, and how expensive or how high quality the parts are. Don't forget about $10K for a good paint job. Is there rust to mess with?
Old Feb 24, 2008 | 12:22 AM
Scott Marzahl's Avatar
Scott Marzahl
If you pay someone $65/hour labor, full chassis, engine, trans rebuild, all new mechanicals, full interior and paint. It is not uncommon to spend well over 1000 hours on a restoration. Basically more than the car is worth at $65K.
Old Feb 24, 2008 | 12:33 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Too many variables. Who's doing the work? What condition is the car in now? Are you willing to shop around for parts?
Old Feb 24, 2008 | 08:10 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Doug
Unfortunately alot more than the car is worth. It makes better sense to do the work yourself if you can and not get into a body off the frame resto.
Old Feb 24, 2008 | 08:33 AM
79VAVette's Avatar
79VAVette
with all the above. There are numerous variables. I bought my from the biggest Bubba to ever touch a vette and I have been paying for it...
I am doing a frame off now on a 79 L48. I probably have more in the orginal purchase and chasis than I will ever get out of it, but it's been a blast so far. Hope to drop the body in the next couple of weeks.
If you are doing it for a hobby, and have a deep bank account you don't mind dipping into, I say go for it. If you are planning on recouping most of your money when done, then you need to look into other investments. Good luck whatever you decide!
Old Feb 24, 2008 | 09:00 AM
MN80Vette's Avatar
MN80Vette
It sounds like BIG BUBBA sold at least 2 Corvettes - 1 to 79VAVette and 1 to me.
I haven't done a body-off, frame-up restoration/upgrade on my '80, but just about. In hindsight, I should have gone all the way, but I didn't know about this C3 Corvette Forum then. The frame is in excellent condition. (That is the only reason I bought this '80 instead of any other '80.)
I am probably going to go back redo a few major things over - primarily everything between the engine and the rear suspension, especially all new wiring and everything else in the dash. I have new body mounts but haven't put them in yet.
In all, I estimate I have $15,000 on top of the $4,000 the non-op original value + $6,000 Unlimited Corvettes/Michael Monthief mark-up/rip-off + $1,000 miscellaneous/shipping costs.
I didn't keep track of actual costs because I really don't want to know because I was afraid I would suffer some sticker shock every time I thought about it. Beside, I don't ever plan to sell it, so recouping any costs has never been a factor in any decision.
Old Feb 24, 2008 | 09:03 AM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
I'm in the hole for a tad over $10K right now. http://www.cardomain.com/ride/2658106/1
And there is always something more that needs work/replacement. Set a budget and expect to have to double it as you get to the point where you realise that you've gone to far to stop now.
The fiberglass body can be misleading as everything under the skin rusts, and rusts, and rusts...wears out, breaks, etc. And while you are at it, might as well UPGRADE everything! Countless retailers/manufactures make a plethera of modern replacement parts, all waiting to drain your bank account, but you'll have an "almost new", shiny, stainless steel tubed & bolted, polyurethane bushed, hot-tanked motored monster. And you get all that after a brief 2 year rebuild that consumes all empty space in your garage. You also gain, for free, the valuable insight of knowlege from wrenching every nut & bolt on your car. Knowing that you never want to do that again is priceless!
Old Feb 24, 2008 | 09:55 AM
Doug Maitlen
The car is a daily driver, but I want to turn it into a weekend cruiser or let my dad drive to work. I plan on teaching my 5 year old niece to drive it when she's old enough and I am definitely not going to sell it. It was my first car and I am still in love with her. Where can I get factory parts? Can I do it myself in my garage if I don't have fancy tools or lifts and whatnot?
Old Feb 24, 2008 | 10:05 AM
Dean_O's Avatar
Dean_O
We are in the process also, and without the motor, driveline. We are in probably 20k to 25k...
Old Feb 24, 2008 | 10:27 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Some factory parts are available from GM and other Vette vendors. Non-OEM parts are available from Vette vendors, but you have to be careful what and from whom you buy. You don't need fancy tools or a lift to restore your car yourself, although air tools are a big help but not required. Obviously, though, if you plan or painting the car yourself, you'll need a spray gun, compressor, and other body working tools. Good luck with the car.
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I agree with the other comments here, depends what you want the end result to be. I did an off frame on our 79 3 years ago, spent over 20k in new parts (didn't need to buy new parts but did) and did all the work except paint, that was another 8k. I have way more into the Vette than it's worth on re-sale, but have the result I wanted, so I paid without worrying about the cost.
The frame off on our 72 hit over 30k. in parts and again paint on top of that. If your going to do it right, so that your happy with the car, like was said before, you better have deep pockets and a lot of time to work on it. And remember, they may never be worth what we have invested in them, except the pleasure of owning one.
Good Luck
To Restoration
