Rear Differential Problems
Old Feb 24, 2008 | 10:41 AM
Gauge0010's Avatar
Gauge0010
Navigator
Default Rear Differential Problems
Finally got my 1969 corvette on the road only to have rear end trouble now have popping noise,jacked up checking it out,have side yoke end play more on the left looks like I'll end up pulling differential.Who do you guys recommend to rebuild unit?Wish I had knew this when I had the trailing arms out to have rebuilt,this is my 1st corvette seems I've had to work on every part on it,but I steel love it,these Corvette's must get in your blood,along with your bank actt.
Old Feb 24, 2008 | 10:57 AM
Scott Marzahl's Avatar
Scott Marzahl
Where are you located, fill out your location in your profile. You can hit up Gary Ramadei in Conn, or if you are close to Texas hit up Mike Dyer or use a vendor like Bairs etc.
Old Feb 24, 2008 | 12:38 PM
Gauge0010's Avatar
Gauge0010
Navigator
Southeast,I have thought about using Bair's in PA.
Old Feb 24, 2008 | 02:14 PM
wombvette's Avatar
wombvette
Before you do that tell us about the poping noise. Does it occure most hot or cold?
Old Feb 24, 2008 | 02:32 PM
gve's Avatar
gve
Put some GM posi additive in first, before you pull the rear end. It might be the posi clutches making the noise.
Old Feb 24, 2008 | 02:37 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
GTR1999!!!!! Gary is
Old Feb 24, 2008 | 08:15 PM
Gauge0010's Avatar
Gauge0010
Navigator
Temperture don't affect it pops when pulling out in reverse and drive.
Old Feb 24, 2008 | 08:19 PM
Gauge0010's Avatar
Gauge0010
Navigator
That is what I was in process of doing when I found yoke end play problem.
Old Feb 24, 2008 | 08:21 PM
Zulian's Avatar
Zulian
I had the same problem on my 77, If your lucky like i was there isnt really much damage, if you drop your rear end and open the back cover, there is a snap ring and the end of each yoke on the inside of the Diff. I had a busted snap ring on mine and after i replaced it, the pop was gone.
Old Feb 24, 2008 | 08:29 PM
Gauge0010's Avatar
Gauge0010
Navigator
Yes,talked to Gary today. I'll pull it out look it over go from there.Thanks.
Old Feb 24, 2008 | 08:35 PM
Gauge0010's Avatar
Gauge0010
Navigator
I'm hoping that is what my problem is I'll just have to open it up and see.Thanks.
Old Feb 24, 2008 | 09:45 PM
wombvette's Avatar
wombvette
Missing snap rings dont cause pops. Maybe you should check the snubber bushing if its making noises when going from first to reverse.
To Rear Differential Problems
