I have read a lot of good things concerning the NGK Iridium spark plugs in performance engines. Many are running them is race motors....Has anyone used them in a high performance Big Block? And with MSD Ignition?
If your car runs a bit better, it's likely not the spark plug design that caused it. It's probably due to the plugs being new and gapped properly compared to the old plugs. In my '69 L71 I have AC Rapid Fire plugs with the gap opened a bit for the MSD 6A. It starts a bit easier and gets slightly better gas mileage (still bad w/4.11 gears), but I ascribe that to the MSD and maybe the bigger plug gap for more complete combustion.
I found out several years back that you really don't need the exotic spark plugs unless that's what the car manufacturer calls for. Maybe the more expensive plugs might last longer, which means the car may maintain its level of performance longer before replacements are necessary. I once tried one of the more expensive spark plugs...SplitFire. The car ran no different and within a few months, two of them cracked their ceramics. I replaced them with oe plugs and the car ran just as fine and no problems.
I've just come to believe if you buy whatever spark plug you like, in the correct heat range and gap it properly, and maintain the entire ignition system properly, your car should run optimally. It's no better than its weakest link.
I disagree.. I replaced my new stock AC Delco's with NGK Iridiums in my 75 new crate engine and my car runs MUCH, MUCH better....idle, pick up, gas mileage...just over all performance...I can definitely feel the difference!!! I too am using the MSD HEI ignition system (used the same MSD for both plugs).
Here is living proof that the power of advertising should never be underestimated. Gald you feel you got your money's worth.
....I don't know about his case but I do believe we are conned bigtime into buying what Madison ave. tells us we should use.......By the way I use Bosch for my BB........Jerrylee///
I disagree.. I replaced my new stock AC Delco's with NGK Iridium's in my 75 new crate engine and my car runs MUCH, MUCH better....idle, pick up, gas mileage...just over all performance...I can definitely feel the difference!!! I too am using the MSD HEI ignition system (used the same MSD for both plugs).
vetteguy75 - Thank you for backing me up here.....I see the same difference. I'm running the original 11:1 compression with aluminum, L88 closed chamber heads, a cam that has 262@.050 duration, modified tri-power carbs (550 CFM 4412 in the middle) amongst many other tweaks and ther is a remarkable difference in performance with the NGK Iridium plugs. I've owned my car since new so I can tell the difference, I have tried them all. Overall NGK's have worked the best for me.
Roughrider - The regular NGK's I pulled out had 70 miles on them and were gaped exactly the same as the new Iridiums, so your assumption regarding old plugs and plug gaps is not valid.
The heat tolerance of the Iridium electrode is far better than any other plug out there, read the specs.
One can disagree all they want, it`s their money. But all thats necessary is in this statement.
I also had both Autolite and Champion racing division confide to me that there all the same, some just cost more than others. BTW, both companies provided me with spark plugs no charge .
I also use and like NGK's... is there really that much of a price difference? I haven't run the numbers but I don't remember feeling like I was paying more for them than say Autolite or Bosch... NGK also has a very informative website and when I asked them for a plug recommendation they got back to me within a few hours with a plug and explanation...
And yes their marketing worked on me as well with their whole "V-power" thing... even if I know the spark will take the path of least resistance... lol... it just sounds cool.
Yes, The NGK Website is most informative, and their customer service tech line is awesome. You can call them and speak to a tech that has all of the answers. I went to the drags to see what brand plugs they were running in the top fuel machines, 95% of them were running NGKs so that s when I switched brands for my cars decades ago.
As far as the cost of the NGK V power plugs they go for around$2.49 each. The Iridium IX's (top of the NGK line) go for $8-$9 each.
