manual conversion
Old Feb 25, 2008 | 12:55 PM
montez27's Avatar
montez27
Default manual conversion
1982 corvette, original
I am thinking about converting to a manual box. Are there any kits out there and will there be any issues with the computer? Just looking for basic info for now. Any other tips or concerns will be appreciated.
Old Feb 25, 2008 | 01:01 PM
markdtn's Avatar
markdtn
You can use 80 or 81 C3 parts to get a driveshaft, console, and crossmember. May can swap with someone wanting to do a 700R4 swap? Pedals fit from 68 up although there are a few differences along the way. I don't think the computer will care, you may have to add a dummy relay so it has a resistance for lockup circuit. The VSS is on the speedo so as long as you hook up the speedo you should be OK there. You will have to change the backup switch because for an auto it's on the shifter. It can be done.
Old Feb 25, 2008 | 02:05 PM
Brandywine's Avatar
Brandywine
Try Keisler...
http://www.keislerauto.com/gm/corvette-c3-kits.html
Old Feb 25, 2008 | 09:48 PM
ngroat7007's Avatar
ngroat7007
Originally Posted by Brandywine
How much do you think the auto to 5 speed conversion will cost?
another thing is what would we want? the tko500 tko600 .64 or tko600 .82?
I ask because i had the exact same question before this guy. Our 82s need to grow some *****
Old Feb 25, 2008 | 11:52 PM
blk79nj's Avatar
blk79nj
Here you go...
http://forums.corvetteforum.com/show....php?t=1951514
To manual conversion
