Quadrajet question
Old Feb 25, 2008 | 09:30 PM
tommyleea's Avatar
tommyleea
Default Quadrajet question
I am rebuilding the quadrajet on my 77 Corvette. Automatic with air, carb #17057204. I have the top off the carb. There is a well where the power piston resides, and next to this well is another, with an adjustment screw, that is supposedly set at the factory. I don't know what it does. The manual says not to mess with it, unless you believe it has been tampered with. I don't believe the carb has been apart before, but I could be wrong. Any advice or experience with this adjustment? Should I just leave it alone? Thanks
Tommy
Old Feb 25, 2008 | 09:39 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
Send your carb to Lars
Old Feb 26, 2008 | 04:15 AM
stingr69's Avatar
stingr69
Adjustable part throttle screw - leave it alone.
I didn't know and read about it after I had already dissasembled it. The adjustment takes specialzed equipment to set it right OR a lot of trial and error. It has an effect on part throttle mixture. You can make a tool to adjust it and punch out a hole in the top of the carb and add a threadded plug to make fast changes in an effort to get it back to where it needs to be.
IMHO - if this one ain't broke, don't fix it.
-Mark.
Old Feb 26, 2008 | 08:05 AM
BigBlockk's Avatar
BigBlockk
If you want to remove the APT adjustment screw, screw it down until it lightly seats. Count the number of turns it takes to seat it. This will give you a reference for reinstalling it.
BigBlockk
Later.....
Old Feb 26, 2008 | 08:07 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
When I rebuilt my Q-jet, I used Doug Roe's book on the subject (which is excellent). I remember in it he said do not attempt any adjustment of that screw. I followed his advice and, BTW, my rebuild turned out great, much to my amazement. Good luck.
Old Feb 26, 2008 | 09:43 AM
tommyleea's Avatar
tommyleea
Thanks for all the help. I will leave as is. Cheers
Tommy
Old Feb 26, 2008 | 09:49 AM
Jud Chapin's Avatar
Jud Chapin
Tommy, why don't you take a few minutes and fill out your profile so we'll know a little more about you.
Old Feb 26, 2008 | 10:52 AM
jim2527's Avatar
jim2527
That screw adjusts the height of the mixture rods in the jets. Under full vacuum it controls how far the rods go into the jets.
Old Feb 26, 2008 | 10:59 AM
tommyleea's Avatar
tommyleea
OK...I think I updated my profile. Thanks
Old Feb 26, 2008 | 11:15 AM
Jud Chapin's Avatar
Jud Chapin
Thanks for the profile and, more importantly, thanks for serving. That B2 is bad ***. Very sorry to hear that we lost one.
Old Feb 26, 2008 | 11:26 AM
tommyleea's Avatar
tommyleea
Thanks, and it will be interesting to see the cause of that one.
To Quadrajet question
