Okay, don't laugh...
My first priority is replacing the wiring, which looks like someone tried to renovate the thing a few years ago and botched the job - all the wiring harnesses are screwed up in one form or another, so I've torn out the interior (no great loss, as some prior owner must have kept his pet goat in there for a year or two) and am doing, I think, okay with that.
However, under the hood, things are different. I know how an engine works, pretty much, but some of the specifics are beyond me. I'll figure it out, but right off the bat, I noticed some odd things that looked out of place, and wanted the opinion of wiser minds.
So:
What the heck is this thing? It's just hanging around next to the carb, looks like it should be hooked onto something useful. Still, that's not as alarming as:
This pipe is just hanging out there, poking out of the cylinder head. What does it do? Is it supposed to attach to something critically important that has already fallen off?
Likewise, this little tube is poking out next to the carb. Why?
Like I said, the car runs okay. It puffs out a lot of white smoke, but I'm not too worried about that now. I guess I'd just like some idea about whether any of these three odd things means the car is going to explode or suffer some imminent fatal problem. Which would be okay, really, as long as I knew why...
Second is the PCV valve, usually hooks to the air cleaner or a vacuum port on the carb.
Third one is the has something to do with The EGR. Can't help there, cuz mine's completely gone.
Finally, somebody has a dirtier engine than me!!!
Good luck, and have fun!!
Probably be a good idea to pick up a shop manual for your year. Even a Chilton's would help a little.
And keep asking questions here... This forum has all the knowledge needed to completely rebuild your car from the ground up... just have to ask, and sometimes, ask the right questions.
Dan
Apart from that, it's in mint condition. Bonus: clipped to one of the springs of the non-functioning headlights was an elderly baggie containing a couple ounces of extremely dry, rotted weed. Looks like someone forgot where they hid their secret stash...
Dan
The second is you PCV valve.
I think the third picture is your choke stove, although the EGR system isn't hooked up either.
As stated earlier... a large amount white smoke is sign of bad head gasket, and could be worse like a craked head or block.
Please post pictures of the the entire car. This forum likes pictures, and you are off to a good start. Even if the car is a rough, you will get good advise on where to start.
Go for it, carpinteriac3!
Welcome to C3 Anonymous. We all have the sickness and love it! Take pride in every step of your journey.
We're all visual kinda' guys. That's one of the main reasons we drive C3's. Pictures are good. We don't have to read all them there words to figure out what yer' talkin' about.
I call it El Diablo *****:
Here's the interior. Hard as it may be to believe, this is actually after some cleanup work:
THE HORROR!
It actually runs great. Makes a hell of a noise (needs new exhaust as well as everything else), has a tough time steering or stopping, but it seems to have strong bones and plenty of life in it yet. It's daunting if you're a neophyte, but hell, it's really just a lot of little machines all put together to make a big machine. And little machines are pretty easy, right?
</selfDelusion>
So, if you eat this "elephant" a little at time, it will get done.
I think it's an excellent project, so good luck with it.
But it does appear to have a lot of rust. Suggest you check the birdcage and frame well before getting too far into this one. The frame is one thing, but if the birdcage is bad...this is realistically a parts car. But still a good deal if it is.
If the frame is good, you have a big driver project on your hands. Probably a good way to stay out of trouble for a few years and get rid of all those pesky dollars you have in your wallet.
Originality is no longer a requirement but has value if only for the functionality. Freedom to modify at will makes the project more fun for many people.Assuming the frame is still there - I agree that you need to get the factory assembly manual to help see what used to be there and figure out if you need any of that stuff you are missing.
-Mark.
this could be that cause of your white smoke/vapor
also check the oil and see if it looks milky.
