Sizing Airflow for intake
Old Feb 26, 2008 | 11:58 AM
lr172's Avatar
lr172
Default Sizing Airflow for intake
I have purchased an aftermarket L-88 hood to accomodate the new 496build. I plan to create a cold air intake for it. However, the structural brace at the rear of this hood is solid so I will need to either drill a series of holes or slots in it to accomate air flow into the chamber. I plan to build a chamber that will have the air cleaner contained within it. Essentially, I will put a plate below the air cleaner to seal the with the chamber.
My question is how much air flow do I need into this chamber and how do I determine how much air flow can fit through a given hole? I thought that a series of 1/2" or 5/8" holes would maintain the structural ridgidity of the brace over long slots. My initial logic was to mainain an opening area at least 1.25 greater than the area of the four carb barrels. However, I am not sure that is enough and I don't have any real experience here.
Any guuidance that can be provided?
Old Feb 26, 2008 | 12:39 PM
S489's Avatar
S489
trying to picture; will the brace have a hole drilled through the front and rear (relative to the car)?
Old Feb 26, 2008 | 01:22 PM
gkull's Avatar
gkull
My Cowl induction hood is completely open at the back with a lower cross brace. You want the opening very near the window to get the ram air effect. To not create a restriction I would think that you would need 10X the area of the throttle bores.
This is a fellow forum members air box design which I also built for a prior motor. I hope that he doesn't have the patent on this!
Old Feb 26, 2008 | 02:37 PM
Little Mouse's Avatar
Little Mouse
That looks really nice copy that.
Old Feb 27, 2008 | 07:01 PM
lr172's Avatar
lr172
I was thinking of a similar setup to the one in the picture, but building it out of fiberglass and attaching it to the hood. Then putting the foam at the base of the filter for a seal. I think I like your version better; Certainly a bit easier to build.
the crossmember on my hood goes all the way up to the hood deck, unlike a real L-88 hood (it is a vanacor). The hood is thin, so I don't want to remove a large chunk of the brace and I believe that round holes preserve a good amount of ridgitiy of a brace. I am now struggling with the issue of airflow. What kind of area for the airflow will be required to support the carb/engine without restricton.
I don't care too much about ram effect. I care mostly about getting colder air into the engine to improve HP and mostly to resist detonation.
Old Feb 28, 2008 | 08:46 AM
gkull's Avatar
gkull
You have to remember that our motors shake and TQ flex. So you have to have a rubber seal.
My aftermarket hood is cut out on the whole indented area next to the rear top of the hood
Old Feb 28, 2008 | 10:07 AM
81fixerupper's Avatar
81fixerupper
The answer to your airflow question isn't as straightforward as you might have hoped. There are a couple of things that will come into play when determining this:1) the air velocity coming through the hole and 2) the pressure drop across an orifice. The first equation is pretty simple: Q=VA where Q is flow in CFM, V is velocity in ft/min, and A is the area in square feet. So theoretically any size hole could flow a given amount of air if the velocity is high enough. The problem lies with the amount of pressure drop a very small hole and high air velocity would cause. You would have to find an equation to find the pressure drop through that hole at your given flows, pressure, velocities, etc. (probably bernoulli's). To make a long story short, I would say just make it (or the sum if more than one hole) as large as at least the cross sectional area of the opening on the carb so that you don't cause an increase in backpressure on the engine causing it to work harder to suck in air.
Old Feb 28, 2008 | 10:45 AM
Matt Gruber's Avatar
Matt Gruber
each square inch is good for 20 crank hp
Old Feb 28, 2008 | 11:04 AM
S489's Avatar
S489
i just did a quick calc that makes me want to check the factory opening! (73-74 functional scoops)
Old Feb 28, 2008 | 01:56 PM
lr172's Avatar
lr172
Matt,
This seems hard to swallow. I have seen the air cleaner intake horns on some those 300+ HP factory engines that couldn't have had a surface area any greater than 10 square inches.
Does anyone know what the surface area on an air clearner horn for the 400+ HP factory engines?
I would like to plan for a 900 CFM airflow, but I don't know the velocity nor how to equat that with area.
Old Feb 28, 2008 | 02:06 PM
lr172's Avatar
lr172
The total surface area of the carb is 10 sq. inches. I think I can easily cut enough slots to create 15 square inches without looking too ugly. It sounds like fewer and larger slots would reduce resriction and velocity. Did I understand that correctly?
Does this seem like a safe plan?
Old Feb 29, 2008 | 09:43 AM
81fixerupper
Sounds like a reasonable plan to me.
Old Feb 29, 2008 | 12:22 PM
Matt Gruber
1st thing before u buy a hood:
FIND OUT THE COWL INTAKE SIZE!
my ecklers hood has
20"x2.25
enough for 900 HP!
me, i cut w/hole saw 6,
1.875" and
3
1.125 for
~20 sq in or 400hp
can u use anemic holes? sure! it's your car, and it MIGHT work satisfactory.
To Sizing Airflow for intake
