Stock size sway bars. Front and Back ??
Location: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
What is the size of a front and rear sway bars on a stock 77 auto with a th350....
I have look everywhere ??
Help CF....
Thanks G
Help CF....
Thanks G
Location: Guantanamo Bay, Cuba (home in Colorado Springs)
1 1/8 front for '80
Only BB Vettes had a rear anti-sway bar.
I put poly bushings on mine and added a 7/8 rear anti-sway bar from Adco.
Note: If upgrading anti-sway bars, you should not have a larger rear than front. It could adversely affect handeling.
How hard is it to add the rear sway bar on my 1977
..... Im getting a VB & P 3/4 in rear sway bar.....
How will this add to my handling ???
I added that same rear sway bar years ago. I had to later add zerk (grease) fittings. The poly bushings squeaked like hell. You will notice a difference in handling. Just add the zerk fittings before installing to save yourself aggravation.
Mine was part of the Grand Touring Package. If you're looking for "best bang for your buck" I'd say add a front monospring first.
OK well I called VB & P Talked to Patty and they are going to email me everything I need to install the parts...Thanks everyone...'
VB&P rocks...
VB&P rocks...
Thats true, it IS just nutz an bolts.
I think my 77 L82 had 1" front and 5/8" on the rear.
My 81 didn't have the rear bar, but the holes were in the frame so it just bolted in, took about an hour.
The front one has 4 bolts and the 2 end links, nothing to it. Just keep an eye on the clearence between the bar and the lower radiator hose fitting, it gets real close.
The VBP kit has some flat bars that bolt onto the top of the read end of the Trailing Arms, thost fit a little snug and it covers up the hole for the TA/Spring bolt, so make sure your happy with ride height before installing them.
My 78 L-82 with the sport suspension came from the factory with 1 1/8" front bar with 7/16th rear bar. I put poly bushings on the front end links and mounts to the frame and an OEM style rear bar from mid america on the rear, 3/4" with polyurethane bushings on the frame mounts.
