C3 x-pipe clearance
Old Feb 29, 2008 | 10:56 AM
1chromebumper's Avatar
1chromebumper
Default C3 x-pipe clearance
Does anyone have an X-pipe on a C3? The muffler shop was giving me grief when I showed him the pictures and pipes. Sounded like he didn't want to really attempt it. I'm thinking there is at least 4+' to make the x junction after that center crossmember. Anyone that can share a picture would be smiled upon.
Old Feb 29, 2008 | 11:21 AM
tshort's Avatar
tshort
CI 7-8 Veteran
My advice: go to another shop!
Here is my 3" system with 3" x-pipe. Make sure you've got some disconnects in front of the x-pipe if you need to drop the exhaust to do any tranny work. There's different ways to do it but I used band clamps.
Old Feb 29, 2008 | 11:55 AM
my mach 5's Avatar
my mach 5
Check this out: http://pypesexhaust.com/sys-vette1.html
I don't have this system, but I did catch it on the net.
Old Feb 29, 2008 | 04:00 PM
73VetteKS's Avatar
73VetteKS
I don't have a photo, but I put a 2 1/2' on my '73, very similar to what Travis shows. Just behind the trans. I have a 350 with 700R4. It's not hard. Hell, if I did it, it can't be hard. :-) Try a different shop.
-Jim
Old Feb 29, 2008 | 04:49 PM
OzzyTom's Avatar
OzzyTom
this was on my 68...
2.5" system, with detachable pipes in front of cross member.
X-pipe with 2.5" Magnaflows at rear.
I had it on the car for 2 weeks, then removed it.
Had a very annoying drone from 1200 to 2200 rpm. Couldn't stand it.
Also the X-pipe made it sound like a late model chev...
Gone back to a straight 2.5" twin system.
If you do want to eliminate the drone with a free flowing X-pipe system with Magnaflows, you might consider fitting some bullet mufflers after the X-pipe, but before the rear axle. Finding a short enough bullet (9") that will fit may be the problem though.... One member here cut a 18" stainless steel bullet in half and welded the ends to suit.
He was quite happy with the end result. Ground clearance does become an issue though.
Old Feb 29, 2008 | 05:43 PM
roscobbc's Avatar
roscobbc
I have always wondered if the design of a muffler with baffles will always have a tendency to resonate at certain revs which will be worse with an auto transmission. The old school 'straight through' mufflers perhaps don't suffer this problem. Certainly my own stainless steel wool-filled (rather than glass) does not have this problem. If seems that baffled mufflers (especially with a cam) are noisy at low rpm and idle, but quieter at speed, whereas glass packs are relatively quiet at low rpm and idle yet noisy when you hit the gas. Does anyone agree?
Old Mar 4, 2008 | 11:40 AM
1chromebumper
Thanks for the photo's guys. I currently have a drone anyway with flowmaster 40's, it's a little higher at 1500-2500 RPM though. Someone told me (on here) that the Xpipe helped to minimize his drone with those same flowmasters. I do appreciate all the feedback and advice
Old Mar 4, 2008 | 01:06 PM
pmazza's Avatar
pmazza
I have a couple of pics uploaded on the 'My Corvette Photos' link. 3" X pipe located behind crossmember and driveshaft loop. No drone with SuperTurbos or the current UltraFlos. I used the ball type of connections at the header so I can drop the entire exhaust quickly (10 bolts).
Phil
To C3 x-pipe clearance
