Installing a 4 speed in a C3
Old Feb 29, 2008 | 11:12 PM
midlifemuscle's Avatar
midlifemuscle
Default Installing a 4 speed in a C3
Im putting my 4 speed back in my C3 and am having trouble getting it to slide in the last 1/2 inch or so. Are there any tricks here?
Old Feb 29, 2008 | 11:31 PM
Scott Marzahl's Avatar
Scott Marzahl
Did you change the clutch or something? If so, did you use an alignment tool to line up the clutch disk so the trans input shaft will slide into place?
Old Mar 1, 2008 | 12:18 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
we need more background info here. just winging it, i think scott is right.
Old Mar 1, 2008 | 10:09 AM
Duke94's Avatar
Duke94
Have a helper depress the clutch pedal while you rotate the output shaft (trannie in a gear) and push the trannie forward. The input shaft has not lined up with the clutch disc splines. Common problem.
Old Mar 1, 2008 | 10:13 AM
bruced267's Avatar
bruced267
Do not use the bolt to pull it forward!!
Old Mar 1, 2008 | 10:31 AM
Lee H's Avatar
Lee H
The last 1/2 inch is the tip of the input shaft not lining up with the pilot bushing. It's all ready through the disk. As Duke94 said, depress clutch and wiggle it in.
Old Mar 1, 2008 | 07:27 PM
dariopop's Avatar
dariopop
!st time I replaced my clutch Napa gave me the wrong plate with the incorrect spline . There are two splines , one is a 18 and the other ( I think ) is 24 . I'm not sure how far it stuck out without going in but I can tell you that it took me about an hour of trying before I finally pulled it back out and figured out what was wrong. I was almost ready to back it out of the garage and check on my fire coverage.
I think your going to have to take it back out and do a look see on the front where the Pilot bushing is. Do you have 2 -6" 5/8 bolts with the heads cut off installed on the two top bell housing holes? If not do so, it sure makes it easier to slide the trans in the last 6 inches and pretty much lines it right up too.
Dario
Old Mar 1, 2008 | 07:49 PM
69autoXr's Avatar
69autoXr
10 and 26
But it sounds like he's into the clutch spines; if an alignment tool was used for the clutch disk-to-pilot bushing, a little wiggling and it should go into place. The pilot bushing is a tight fit on input shaft, and you've got all that weight (the trans) cantilevering off the back-push up on the back of the trans a bit and give it a little wiggle-it should slide right into place.
If an alignment tool wasn't used then all bets are off.
I wouldn't depress the clutch; if the input shaft isn't lined up with the pilot bushing and you push the clutch it'll throw everything off. Then the trans has to come down again, and the disk will need to be lined up again-with an alignment tool.
Old Mar 1, 2008 | 08:29 PM
bruced267's Avatar
bruced267
Depressing the clutch will not throw any thing off! All it will do is let the disc move a little, Hes already on the disc, if not it would be more like 3" off not a 1/2 off. We have to do this to 4wd trucks when we replace the clutch. The aligment tools are perfect and often let the disc sit a little low!
Old Mar 1, 2008 | 11:44 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
Not 100% aligned with the pilot bearing. I ddin't have a helper so I used a com-a-long on the fork - tranny slide right in.
Old Mar 2, 2008 | 10:25 AM
Alwyn678's Avatar
Alwyn678
Darn good Help and Info. here! Why not go with a SIX SPEED TRANNY?
Old Mar 2, 2008 | 07:20 PM
midlifemuscle
Default All good advice
All good advice. I eventually got it in with a helper depressing the clutch!
Old Mar 4, 2008 | 07:17 PM
rw6007's Avatar
rw6007
Hi guys. While on the subject of C3s with a 4 spd transmission. Can anyone tell me why my '81 has started grinding the gears when I go to shift in reverse. I have no problems and the forward gears all synchronize smoothly. In order to shift into reverse without the heavy grinding noise, I have to run through several of the forward gears first. What do I need to do? Does this represent a major problem with the transmissions. By the way, the vehicle has 50,000 original miles, I'm the second owner and it has never been raced or wrecked.
Your very informative responses will be greatly appreciated.
Old Mar 4, 2008 | 09:28 PM
IronJen's Avatar
IronJen
Abby Normal
does this happen even if you start the car with the clutch in and try reverse? me thinks 1st gear synchro...
Old Mar 5, 2008 | 07:11 AM
Duke94's Avatar
Duke94
Sounds like it needs a clutch adjustment as it does not disengage fully.
To Installing a 4 speed in a C3
