differential rebuild?
Old Mar 1, 2008 | 08:22 AM
AWilson's Avatar
AWilson
Default differential rebuild?
I am doing a frame off. My differential seemed to be working just fine when I started this restoration. I have been trying to make up my mind for 2 weeks whether or not I should rebuild it or not. Looks like a good rebuild cost over $1,000! Money for this project is starting to get tight.
Anyway, this morning I realized that I don't have to rebuild it if it isn't that difficult to get out later,,,if I ever need to.
So the question is Is it difficult to pull the differential after the car is back together? Looks to me like it could be done in 2hrs. If so then I'll just change the fluid, paint the case and put it back. Maybe new seals.
Any advice guys?
Old Mar 1, 2008 | 08:54 AM
wombvette's Avatar
wombvette
Any advice guys?
Gears are designed for infinite use. If there is nothing wrong with it, then leave it alone. Clean it up and change the seals while it is out. Also change the fluid and additive. You are correct, the rear can be easily serviced if it is needed later.
Old Mar 1, 2008 | 09:13 AM
Retro78's Avatar
Retro78
Measure the end play on the side yokes. If the play is small...eg .020 or less I would not rebuild it.
Old Mar 1, 2008 | 09:34 AM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
With above advice. Shouldn't take much more then an hour to remove. Biggest issue I had (on all 3) was the crossmember. If you've had that out, the next time should be a piece of cake.
You didn't memtion the mileage but the posi unit in my 76 blew at 131K. I think Bair's does rebuild at $565 plus any additional hard parts.
Yeah - replace the fluids, paint it & put it back.
Old Mar 1, 2008 | 09:45 AM
AWilson's Avatar
AWilson
Default Diff. end play .017 and .028
I appreciate the comments. I found a wa y to measure the end play. one side is .017 the other .028. So one is above the .020. But I assume this is a reference? Either way, I'm thinking its a safe bet to move forward and NOT do the rebuild.
Agree/disagree?
Old Mar 1, 2008 | 09:48 AM
AWilson's Avatar
AWilson
The cross member is out and new bushings will go in.
Old Mar 1, 2008 | 10:13 AM
L82shark's Avatar
L82shark
St. Jude Donor '08
Here is some advice Gary gave me when I was doing mine:
Check the endplay in the yokes. If over .040" remove them to inspect.
With the cover off, use a 90* pr of snap ring pliers and remove the snap rings from the yoke. Pull the yokes out and install the snap rings back. Then measure from the face to the ring should be in the .180-.187 range. If you find it less then .170 I would replace them, but keep in mind that the posi is probably sloppy too so even if you replace the yokes you may still have over .030 endplay. end quote
I ended up replacing the seals and both of my yokes and that cured it.
Old Mar 1, 2008 | 10:21 AM
AWilson's Avatar
AWilson
This seems to be good advice. So this coupled with a e-mail to Gary and I should be ok. I will do a basic inspection and decide from there. Seeing as how Gary says endplay of .050 or less tells me I should be ok as mine is much less.
Old Mar 1, 2008 | 07:33 PM
GTR1999's Avatar
GTR1999
If your endplay is what you say then you're ok. The 68 will have the weaker posi case and spiders and the better clutches.
If you had no issues, then pull the cover and clean the posi case. If there are no cracks in the window or side holes,drive it. If you see any cracks pull it out, replace the case and rebuild it.
You can a basic rebuild(little parts beside a master kit included) for $600-$800 from most places, the better jobs are double that easy.
To differential rebuild?
