New Member Advice
So far, I've done the following:
Crane Gold Race Rocker Arms - (plus new pushrods, ARP headbolts and carb studs)
Holley 4150 650cfm Carb, doubled the size of the accel pump
HEI Distributor, chrome drop air cleaner
Summit Alum. Cylinder Heads-64cc chamber, 200cc intake runner. I had these machined to increase the compression ratio to approx 10.5 to 11:1.
Edelbrock Performer Intake Manifold - had to do machining mods here so it would fit the different angle on the machined heads
Hooker SuperComp Headers (ceramic coated & wrapped)- 1 3/4", plus full 2.5" mandrel bent 304 stainless exhaust, borla mufflers
Maintenance/Restore Items: New Brakes, replaced brake lines, new Centerforce clutch, new shocks, rear shock mounts, replaced some vacuum lines/actuator/check valve, new driveshaft & u-joint, yoke, front coils, replaced trans and diff fluid, Stub Axles, strut rod camber bushings,
I'm still thinking about doing more and would like some advice about:
1.) Better Intake with Hi-rise hood - I'd still have to machine the intake to match the heads. Not sure if I'd need a larger carb too
2.) cam & lifters - Not sure which to get for the biggest performance gain
3.) 5 or 6sp transmission or maybe modifying original muncie 4sp?
4.) Tires - I was thinking about 255/60/15 all around?
5.) Finish off rear suspension - half shafts and trailing arms
6.) Anything I'm missing or would give more bang for the buck (either safety or performance)?
Is this a L-48, original low compression motor or a L-82 motor with the stock cam in it right now?
If this is the stock L-48 cam, you have way too much compression for that cam. L-82, different story.
It sounds like you want a high RPM motor and you may be building it on a L-48 platform, not the best idea IMHO.
You have the nice air induction hood on the '73, I'd stick with it and use the Performer intake.
If you go with the 5 speed, you'll more than likely want a 3.08 rear end, is this a 3.36:1 now?
Honestly, I'm not sure I want a high RPM motor. I just want to add more power to the original engine. And, I may not be adding the right pieces or doing it in the right order which is why I started the post.
Thanks for the reply.
You might be best off building a 383 for tons of torque and keeping the original motor for the cars value.
I'm not doing most of these mods myself. So, the 10.5-11:1 is probably a bit of a stretch.. it may be more like 10:1. That was a guess/goal the mechanic gave me. When you say build off a 383, does that mean new crank, rods, pistons but keep the matching block? And while we're down there, get a more agressive cam?
