Cleaning Carbon from piston tops?
Old Dec 6, 2001 | 07:49 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Cleaning Carbon from piston tops?
What's a good & preferably easy method to remove carbon deposits from my piston heads? Sand paper? Steel wool?
Old Dec 6, 2001 | 08:11 PM
63Banshee's Avatar
63Banshee
From: WANTED: '68 rear valance with b/u light assemblies IM, e-mail, or PM me here. Thanks!
Default Re: Cleaning Carbon from piston tops? (1970 Stingray)
Are you talking about leaving the pistons in while cleaning??? Try this and you’ll probably do more harm then good. How do your spark plugs look? You may just need to run a hotter plug.
Old Dec 6, 2001 | 08:16 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: Cleaning Carbon from piston tops? (63Banshee)
Leaving them in. Plugs are Bosch platinum and the electrodes have a little brownish tint and 2 have a small amount of carbon on the side of the electrode.
Old Dec 6, 2001 | 08:19 PM
Bans25's Avatar
Bans25
Those don't look bad at all to me... I wouldn't touch them..
-Bill
Old Dec 6, 2001 | 08:52 PM
LT1driver's Avatar
LT1driver
Default Re: Cleaning Carbon from piston tops? (Bans25)
I wouldn't touch them either, not worth the effort for any gain you would see. :cheers:
Old Dec 6, 2001 | 09:01 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
engines do not make max HP till the piston tops are coated to help hold in the heat. :chevy
Old Dec 6, 2001 | 09:12 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: Cleaning Carbon from piston tops? (clem zahrobsky)
Thanks guys, wife doesn't agree but she doesn't know engines! I'll leav'em as is.
Old Dec 7, 2001 | 12:41 AM
Wrencher's Avatar
Wrencher
Definitely leave 'em alone. those look fine.
Hans
Old Dec 7, 2001 | 12:58 AM
ScubaJKD's Avatar
ScubaJKD
Default Re: Cleaning Carbon from piston tops? (Wrencher)
I would not touch them. If you are concerned about carbon deposits just do an induction service every 15K miles and keep her clean and running mean.
Old Dec 7, 2001 | 02:14 AM
Techno's Avatar
Techno
Default Re: Cleaning Carbon from piston tops? (ScubaJKD)
I used crystal simple green to dissolve the carbon and gunk. But This was for the parts that were removed. Heads and exhaust, valves, springs, everything I could soak in it. The stuff dissolved gunge without scrubbing. I also had carbon growths on some of these parts. Yours look only cosmetic, from the look of the pistons.
Old Dec 7, 2001 | 06:48 AM
nastee383's Avatar
nastee383
I have done mine before when I had the heads off and time on my hands but it probably served no good purpose. My understanding is the black stuff is a by product of using unleaded fuel. They were probably black again after a few miles of driving.
To Cleaning Carbon from piston tops?
