New 427 SB Almost Done.....
Old Mar 6, 2008 | 08:02 PM
C3 Stroker's Avatar
C3 Stroker
Default New 427 SB Almost Done.....
.....And now I am deciding how to feed my vacuum accessories. I have a World Motown manifold which does not have the vacuum port hole for the plug needed to supply my power brakes, auto trans, and headlights/wipers.
I think there was a thread showing a pic of access drilled in the rear of the manifold plenum(?). I am considering this, but has anyone just used the large access from the carb?.....any problems? I'm using a Quick Fuel (Holley) 950.
Thanks for replies.
Old Mar 6, 2008 | 08:12 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
My Race Demon does not have a port in baseplate so I drilled the manifold, if your Holley has a port you can use that
Old Mar 7, 2008 | 08:04 PM
C3 Stroker's Avatar
C3 Stroker
[QUOTE=MotorHead;1564426331]My Race Demon does not have a port in baseplate so I drilled the manifold, if your Holley has a port you can use that
Thanks for the pic; my carb has the large vacuum port, so I'll use that.
Post info when your 427 sb is done
Old Mar 8, 2008 | 12:27 AM
Solid LT1's Avatar
Solid LT1
Tap the intake manifold! the vacuum source at the carb is too variable with throttle position. You need a more consistant source from the intake plenum.
Old Mar 8, 2008 | 04:48 AM
panic's Avatar
panic
Pls educate me (and sorry if it seems a small hijack ): i have two tapped vacuum outlets in my 850 mighty demon, and the vacuum outlet on the distr is tap as well...
Would these vacuum connections be any good in a 570hp SB driven with no spare? The engine came from the builder as it is (all holes tapped)...
Old Mar 8, 2008 | 10:32 AM
gkull's Avatar
gkull
Panic, Your carb manual should indicate which carb port is "ported" and "unported"
Vacuum advance should be on ported vacuum. So it doesn't see much vacuum at idle. It should only see the vacuum at cruise with the throttle blades cracked open.
Vacuum to the brakes, head lights, interior controls....... All need full unported manifold vacuum
C3 stroker I'm using the Motown intake on my motor also. It is about the tallest manifold made.
I had to go down to a 2 inch K&n with a big dropped base and open element top just to clear my hood.
Old Mar 8, 2008 | 04:22 PM
C3 Stroker's Avatar
C3 Stroker
Decided after all to tap the manifold.
The Motown is rather tall.....I previously ran an RPM Air Gap which is also tall, but I no longer have it so I can't compare. With the L-88 hood and 1" spacer, I had 1/4" hood clearance with a 3" air cleaner. I'm hoping for the best.
To New 427 SB Almost Done.....
