Rear Window 74 Vette Coupe
Old Mar 7, 2008 | 12:36 PM
JHPOWER's Avatar
JHPOWER
Cruising
Default Rear Window 74 Vette Coupe
Would Like To Know Any Info On Reinstall Of Window Such As Gasket Or Sealent Used For This ,hh
Old Mar 7, 2008 | 08:31 PM
A88FXRS's Avatar
A88FXRS
get a tube of black urethane, semi hardening. works great
Old Mar 7, 2008 | 08:39 PM
'75's Avatar
'75
I recommend using light coat of urethane on the body, then butyl tape, then thin coat of urethane on top of that, then put the glass on that. The reason is, If you just use urethane, you will probably break the glass if you ever have to remove it. This is what the body shop did to mine, front and rear.
Old Mar 7, 2008 | 08:48 PM
hwcoop's Avatar
hwcoop
This should work for you
http://www.corvetteforum.net/c3/vette73/B_RWINDOW.htm
Old Mar 7, 2008 | 09:14 PM
RunningMan373's Avatar
RunningMan373
One of the tricks is to put the ribbon of sealant onto the car fiberglass and carefully install the window in the correct palcement, so that when the window squishes the ribbon, it fills the gap onto the rear deck, the placement is important.
To Rear Window 74 Vette Coupe
