Thanks everyone. Before I can do anything more I'll have to remove the windshield and access the total damage. I'll call a windshield company here in town and see if they are comfortable with coming to the house and removing it here. Again, you folks are great, thank you!!!
Front windshields usually crack on removal..although some do come out ok with luck. The good news is that new glass installed at your home is cheap. $300 for glass including installation at your home. If it was mine, I would take it our myself(likely will break) then call the glass company when you are ready for the replacement. The modern adhesives they use on reinstallation will not dry and crack like the orginals...which is also one of the reasons for many rusted out birdcages.
Bottom line is you need to replace the rusted out areas. If you cant do the repair your self,then find a good shop that wil do it for you. There is no way to sugar coat that kind of damage.
Dont worry though. It is very fixable, and if done correctly you will never know it was even there.
I did 2 windshields in the past and did not have any problem at all. You need to do it carefully and the old style, possibly with a helper. Get yourself soem of that iron wire (copper wire) and two handels. Cut of a usable length of wire and put it in the handles. Start sawing through the sealer in one of the top corners. Once you are through the corner and you see the wire coming out on the inside, remove one of the handles, pull the wire through the inside and reattach the handle. Then work your way around the windshield in a sawlike motion. It would be best to remove both dash and trim to avoid damage. Make sure you keep the inner handle pulled away from the windshield. The outer should be pointing radially to the outside. Avoid pressure on the windshield at all costs.
Oh and when you start make sure that you are sawing through the sealer and not the windshield
Takes about 10 minutes like it is said and saves you money.
QUOTE]
When I removed mine I made sure that I was cutting UNDERNEATH and below the adhesive, between it and the frame.
I did this in an effort to keep any little bit amount of pressure away from the glass, thinking that the adhesive would help to cushion the glass a little as I was cutting. WD-40 seemed to help loosen up the adhesive, but it also made a bad mess of the stuff, too!
I took out my dash, wiper doors, and t-tops to give myself mobility in as many directions as I could.
I think that I might try this. I did some pre-op and am puzzled on how to remove the chrome moldings along the side of the windshield? Are there some hidden screws or clips?
Yes, the last 2 screws you need to remove--one on each of the corner mouldings-- are obscured by the top of the windshield (at least on mine). Juuust couldn't get a phillips screwdriver in there to remove them. Too close to the windshield and at the wrong angle for my comfort.
Sorry, thats not what you were referring to I think. The side mouldings come off with 3 screws that are hidden by the weatherstrips. You might be able to find them by gently poking around with a screwdriver. Also don't forget the screws holding your weatherstrips to the body at the very bottom on the body by the top of the door.
That is not that hard a fix, provided the rust is confined to the upper header. However I agree, the water had to go somewhere and it probably ran down into the birdcage and collected down there. So I would do as the others stated and verify the complete birdcage structure. You can buy a compete windshield frame for about $600. They normally come in three pieces, upper header (where yours is rusted) and two sideposts. If you are not the do it yourself type I recommend you research for a good shop to do it. If you decide to do it yourself, take measurements to the top corners and center of the header from at least two central locations (front and rear) so you can ensure you get it back in the right location. If you get it wrong you will have issues. You can remove a windshield without breaking it, but I dont have the patience and sooner or later I end up breaking them, so figure that into your cost if you want.
With the kind of damage I've seen in the following posts I had an idea!!!(Maybe good maybe stupid!) Could these areas be sandblasted and then be filled with lead? What do you guys think???
