New starter wont 'start'?
Old Mar 9, 2008 | 12:21 PM
77vetteuk's Avatar
77vetteuk
Default New starter wont 'start'?
Just installed a new starter motor (Delco re-man), tuned the ignition and got nothing but a 'click' from the starter?
Couple of minuets later i disconected the battery to put it on charge and as i removed the negative terminal i heard the starter 'click' again?
Went underneath to check the wiring connections etc all looked ok but the solenoid felt hot.
It seems like the solenoid must have binded and only released when the battery was disconnected even though the ignition was off?
No shims where in place with the original, so i installed the new one with none.
Old Mar 9, 2008 | 12:47 PM
73 LS-4's Avatar
73 LS-4
It's possible you may have gotten a bad one. What problem did you have with the previous starter?
Pat Kunz
Old Mar 9, 2008 | 01:14 PM
77vetteuk's Avatar
77vetteuk
Previous starter was suffering from heat soak. Had the new one for quite a while but waited untill i replaced my headers for coated ones to fit it. Just fitted new exhaust/headers so fitted the new starter while it was all out the way.
I've just been out and shifted the the bottom pulley a little and i heard the starter gear 'ping' back. Tried to crank it again with the ignition- only a click again, another click when i disconnected the battery,then again moved the bottom pulley to hear it 'ping' back as before?
Old Mar 9, 2008 | 01:30 PM
Durango_Boy's Avatar
Durango_Boy
Check your Battery connections and at the starter. If there is even a tiny strand crossing, or a corroded or loose connection...even the frame ground, can cause the clicking you're hearing.
As mentioned above, it may also just be a bad solenoid on the new starter. I have had one of those before too.
Old Mar 9, 2008 | 01:58 PM
77vetteuk's Avatar
77vetteuk
Thanks,
Before i re-connected the wires to the starter/block etc i sanded all the connections/mating surfaces for good connection.
I shall check for any wires crossing etc at the starter tomorrow.
Right now im guessing its the gear binding on the flywheel though and maybee wants shimming. I purchased 3 new shims back when i bought the starter.Every manual i have just says re install same amount that came out, no mention of actually setting it up?
Does anyone have any info on shimming the starter/checking clearances etc? or is it just a case of stick one shim in at a time and try it? :-/
Will go over them connections first though.
Old Mar 9, 2008 | 06:32 PM
Five-spot's Avatar
Five-spot
Did the auto parts store test the new starter when you bought it? We got a replacement several years ago that was stuck out of the box. We spent almost a full day on what should have been a two hour job trying to track it down, before we figured that out.
Old Mar 14, 2008 | 12:59 PM
77vetteuk's Avatar
77vetteuk
Tried shimming it-still didnt spin,
Checked for voltage at the 'S' terminal on solenoid- fine,
Tried jumping the two terminal- still didnt spin.
Removed my new headers- pulled the starter to bench test it-
The gear is moving out but not spinning, looks like i got sent a bad one So that was a waste of time and money
Bought from a large US corvette parts supplier from there catalog, had it shipped to the UK.
I like the way it says on the box "premium quality remanufactured"
"All units are 100% tested to assure compliance with oem performance specification"
Well if thats the case then why dont it work!!!!
Not happy- like mentioned above- what should have been a two hour job turns into an all day'er
Old Mar 14, 2008 | 01:10 PM
S489's Avatar
S489
i know it doesn't fix the real problem, but i think i would try taking both units apart and making one - hopefully it would work for a while . . .
To New starter wont 'start'?
