Royal Purple Oil
Any cam that uses a "flat"-actually slightly concave- bottomed lifter is a flat tappet cam. This would include any of the factory style cams found in all Vettes up until the later C4 years (around 86-87), whether hydraulic (L-79, L-82, etc) or solid (LT-1). As opposed to hydraulic roller cams, which have been found in all factory passenger car small blocks (to include 92-up LT1 and 97-up LS motors) since the mid to late 80s. Hydraulic roller lifters are similar to the flat tappet lifters in the way they work, but they have a small wheel pinned to the bottom that actually makes contact with the cam lobe, rather than the lifter bottom itself spinning on the lobe. They also have guides that the lifters ride in (they look like a figure 8 sort of, commonly called "dogbones", and they are held down to the lifter valley by a sheetmetal brace (secured by bolts in the lifter valley) often called a "spider".
Because of the increased friction, the flat tappets are more sensitive to lubrication, and need oil with plenty of zinc additive to live. Due to emission requirements, most of the zinc has been removed from current passenger car formulated motor oil. This leaves a few choices...use a motor oil intended for big diesel truckslike Delo or Rotella- they still have the additives, but may not for much longer-; run a racing formula motor oil; run the specialty oil that someone is having blended to combat this problem (someone please chime in, its been posted here before but I don't have the info); or switch to a hydraulic or solid roller cam. Hydraulic rollers are much more expensive (most cam companies sell a "retrofit" hydraulic roller for older engines), unless you are building a new engine and use a later block already set up for it (taller lifter bores, drilled valley, cam retainer plate). They do last longer, offer more agressive profiles, and are easier to break in-just cover the lobes with motor oil, put some assembly lube on the journals, stick it in and run it. Solid rollers have similar advantages, but have a higher RPM range (lighter lifters),cost much more (no factory-based parts), and dont do well on the street (they are made for higher RPM ranges; extended idling will often kill the lifters, and the profiles are usually very aggressive and require stiffer valve springs-causing more maintenance).
Send my your e-mail and I'll send you an oil test I got on PDF, real eye opener for those running Mobile one.
