Horn Relay ?
Old Mar 11, 2008 | 07:30 AM
abuguy's Avatar
abuguy
Default Horn Relay ?
i can't find the horn relay on my 77. repair manual shows it to be above the fuse block but i have had no luck finding it or the socket it plugs into. not sure exactly what it looks like(round or square) so maybe i am overlooking it?
thanks,chris
Old Mar 11, 2008 | 11:04 AM
dannyman's Avatar
dannyman
Locate fuse panel wire harness coming out of top of the fuse panel. Follow to first component which is the horn relay. Rectangular, plugs into connector at the harness, directly above the fuse panel.
Old Mar 11, 2008 | 11:28 AM
76stingracer's Avatar
76stingracer
Mine has a light blue cover (76). Kinda hangs right above the fuse panel and clutch pedal.
Old Mar 11, 2008 | 07:28 PM
abuguy's Avatar
abuguy
Thanks guys i found it ! it was brown and very hard to see. it checked out ok so problem lies elsewhere..
thanks,chris
To Horn Relay ?
