Comp Cams High Energy 268H Vacume?
Comp Cams High Energy 268H with 1.6 rockers, runs great but head lights very sluggish and now have a leaking oil pan.
Xe is a different grind. That cam should get you enough vacuum though. Are the lights slow at all rpms? If idle only, I would not only look for vaccuum leaks but also do a good tune. May want to apply a vacuum to the actuator with a hand vaccum pump and check them out for faults.
Xe is a different grind. That cam should get you enough vacuum though. Are the lights slow at all rpms? If idle only, I would not only look for vacuum leaks but also do a good tune. May want to apply a vacuum to the actuator with a hand vacuum pump and check them out for faults.
My CC 268H hyd flat tappet idles at 650 rpm with close to 17" of vacuum - after tuning the BG Mighty Demon 650 carb. At 1000rpm it pulls over 20". Maybe you have a rocker adjusted a little too tight and a valve is not closing 100%? Also, check every vacuum line/connection to make sure you put everything back on securely.
OK found the problem the vacuum system filter was blocked. Blew it out and that seamed to do the trick. Today i ordered a replacement filter.
Thanks all........
Thanks all........
