Adjustable Rear Strut Rods ?
Old Mar 11, 2008 | 11:52 AM
DL9179's Avatar
DL9179
Default Adjustable Rear Strut Rods ?
I was wondering if anybody can tell me how i adjust my adjustable rear strut rods on my 77 enough to get it to the alianment shop , because my tires are slanted in alot at the top ?
Old Mar 11, 2008 | 12:47 PM
Gordonm's Avatar
Gordonm
Loosen the two locknuts and turn the adjuster rod. If the tires are in at the top you want to shorten the rods some. Once you have adjusted them roll the car back and forth a few times and recheck the camber of the wheel. You should be able to get it pretty close just doing this by eye. Don't forget to lock the locknuts back down or they will loosen on the trip to the shop.
Old Mar 11, 2008 | 01:31 PM
DL9179's Avatar
DL9179
Ok you say lock nuts , i know the rod has two bolts at each end of the rod do you mean the nut on the bottom of the shock bracket ,sorry but suspesion is not my forte !
Old Mar 11, 2008 | 02:33 PM
Gordonm's Avatar
Gordonm
No there are two nuts on the strut rods. Loosen them and the rod will turn. Run them out against the tube and tighten them back down after the adjustment is made.
Old Mar 11, 2008 | 02:36 PM
TWINRAY's Avatar
TWINRAY
I did an adjustment with a level and didn't have to go to the alignment show. Just crank about 1/2 degree negative and you're good to go.
Before:
Cut a piece of wood same length as the wheel rim
After:
Now, if you replaced ball joints or TR ends, that's a different story.
Old Mar 11, 2008 | 02:46 PM
Gordonm's Avatar
Gordonm
You are actually running positive camber by your pictures. Negative is having the wheel tilt in at the top. You do want to have slight negative camber on a stock suspension.
You are right about the level. You can come real close with a good level.
Old Mar 11, 2008 | 03:00 PM
TWINRAY's Avatar
TWINRAY
First shot is the before . Last shot is the after. You can't tell from the camera angle, but it's a bit negative that I judged to be about 1/2 degree (as the crow flies).
ps. nice set-up you got with your car there buddy!
Old Mar 11, 2008 | 03:11 PM
Gordonm's Avatar
Gordonm
Gotcha!
Thanks. I have to put in some new pictures of the setup now.
Old Mar 11, 2008 | 04:39 PM
DL9179's Avatar
DL9179
Ok thanks i think i have the idea now ,i will try that later when i get home again thanks !!!!!!!!!!
Old Mar 11, 2008 | 05:05 PM
TWINRAY's Avatar
TWINRAY
You'll have to probably do it 3 times (I did) to get it right. Do it, drive around a bit, pull it into the garage and check it again. It'll settle after you drive it.
To Adjustable Rear Strut Rods ?
