Instrument Light's out...
Old Mar 11, 2008 | 01:34 PM
koni9's Avatar
koni9
Default Instrument Light's out...
First off, All of my gages work. My Interior light works and turn off after the door is shut. My headlights work. The problem that I have is that I have no Speedo, Tach, or gage cluster lights. My dimmer will roll and I can get the interior light to turn on and off, but yet not dash lights? Is it my dimmer coil?
Old Mar 11, 2008 | 01:52 PM
dholifield's Avatar
dholifield
Koni, are your tail lights out as well? Mine did the same thing, i checked all my grounds, even changed the light switch and they still didnt come back on. Turns out the fuse in mine had unseated because of a bent holder. If you need a switch i have one that i will sell since i dont need it. Im pretty close to you in Birmingham. Don
Old Mar 11, 2008 | 03:21 PM
koni9's Avatar
koni9
Yeah man.. My tail light don't come on either. That would be great if you could send it to me.
Old Mar 11, 2008 | 03:22 PM
koni9's Avatar
koni9
So your fuse block was bent? or the fuse itself?
To Instrument Light's out...
