78 L82 engine question
Old Mar 12, 2008 | 10:30 PM
tom benjamin's Avatar
tom benjamin
Default 78 L82 engine question
is the L82 engine in a 1978 pace car the same L82 engine put in the std.corvette of that year? I have an advertising clip from that year that states; exclusive to the L82 pace car engine would be forged pistons,special heads,& cam and 4 bolt main. are these specs correct,and are they the same for all L82s of that year? also,what other years was the same L82 engine setup & specs the same????
Old Mar 12, 2008 | 11:07 PM
fauxrs2's Avatar
fauxrs2
All 78 L-82's are the same.
Steel crank
forged pistons
4 bolt mains
2.02-1.60 valves
screw in studs & guideplates
Aluminum intake
2 1/2" exhaust (after the manifold)
dual snorkle air cleaner (which became std. in 79)
Old Mar 13, 2008 | 03:57 AM
hunt4cleanair's Avatar
hunt4cleanair
The reference may have been to the actualy Pace Car used to pace the Indy 500. There is some question whether the engine was a stock L82 or whether it was tweaked to sustain the high speeds.
Old Mar 13, 2008 | 08:07 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Same engine. Only 2 engine options available in '78, the standard L48 and the higher HP L82.
To 78 L82 engine question
