March Sale - Offsets
Old Mar 13, 2008 | 09:07 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default March Sale - Offsets
C2 & C3 (63-82)
Bare offset t-arms are $350.99 and include
Part Number TA-06
• Gloss Black Powder Coating
• Rubber or Poly Bushings
• Spring Bushing Retainers
• Cable Guides
New T-Arm Studs are $12. for all 8 and includes lock washers and nuts.
Complete Offset T-Arms are $970 for the pair. Core charge is $390.
Part Number BAO-44-L/R
• Complete offset t-arms include
• Both offset t-arms
• New backing plates
• Bearing supports
• Spindles
• Caliper Mounting Brackets
• SS Paring Brake Hardware
• New GM Style Shoes
• New Rotors
• Timken Bearings
New T-Arm Bolt & Shim Kit $44.99
Part Number TA-23S
• Kit includes SS Shims to align both the right and left side.
• 2 New pivot bolts with washers, nuts and cotter pins.
Here are the 3 links provided to order online. Prices are already adjusted on our site. You can call your order in as well. There is a 1 week lead time for the complete offsets.
Complete Offset
http://www.vansteel.com/index.cfm?fu...p=1892&ID=2784
Bare Offsets
http://www.vansteel.com/index.cfm?fu...p=1801&ID=1837
T-Arm Studs - Mounts the arm the the bearing assembly (2 kits required)
http://www.vansteel.com/index.cfm?fu...p=1801&ID=1705
T-Arm Pivot Bolts & SS Shim Kit
http://www.vansteel.com/index.cfm?fu...p=1801&ID=1860
