78 L82 air intake duct ???
Old Mar 13, 2008 | 11:10 PM
tom benjamin's Avatar
tom benjamin
Default 78 L82 air intake duct ???
I just purchased a new front air intake duct to replace the old cracked orginal. On the new duct the wide portion that extends over the radiator has the top section removed, unlike my orginal which is an enclosed duct all the way out. Did they remove the top on the new one to allow more air flow, or do I have the wrong duct? They could not answer this at ecklers. (this is on a 78 L82 dual throat front air intake).
Old Mar 14, 2008 | 12:38 AM
timbo79's Avatar
timbo79
The reproduction ones are designed a bit different. They are not as original. Before I switched to TPI, I ordered a new one to try and fabricate an intake and it was different. I saved the old one in case I ever decide to return to original 79 in the same as the 78 L82
Old Mar 14, 2008 | 09:17 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
Can you post a pic? Installed a new one as mine was missing. It has a long bottom tab that slides under the radiator upper bracket and extends forward over the rad.
Old Mar 14, 2008 | 04:25 PM
SLVRSHRK's Avatar
SLVRSHRK
The units you can buy from the vendors are the second generation design by GM. The original design had the enclosed mouth the whole way through.
Old Mar 14, 2008 | 07:21 PM
Duke94's Avatar
Duke94
The replacement I bought for my 78' didn't have the top part either. It is a "functional" replacement.
Old Apr 21, 2008 | 10:47 AM
geofamy's Avatar
geofamy
8th Gear
I am looking for the L82 79 front air intake duct I do have the side piece? amygeof@tds.net
To 78 L82 air intake duct ???
