74 Big Block Smog Question
Old Mar 14, 2008 | 01:22 PM
ROBRICCI's Avatar
ROBRICCI
Default 74 Big Block Smog Question
ok...heres one for the experts...
i recently purchased a completely restored smog setup for my 1974 LS4 convertible...as i understand it...everything is correct for my car...except the actual smog housing as it has a automatic transmission part number - instead the correct part number for a 4 speed....
was all i could find close at the time...
regardless..everything else is correct and it is a truly beautiful unit - except - and will really look great on my retored car except -
i think i dont need it...
from what i understand...my engine pad is stamped "CWM" which is correct for a 4 speed ls4...but if it were a smog car...it would be stamped (i think) CMT?
anyway...hopefully somebody knows...cause if i dont need it...and i hope i dont....its for sale -
and it is the nicest restored unit i have ever seen....also..it has all the correct hoses and clamps and brackets...
RR
Old Mar 14, 2008 | 09:29 PM
trw's Avatar
trw
All 73-74 454's had a smog pump.
The CMT is a California smog equipped car (sold new in California).
Even back then Cali had tougher smog laws than the Feds.
Terry
Old Mar 14, 2008 | 10:06 PM
ROBRICCI's Avatar
ROBRICCI
so what is the difference between a california smog car CWT (454 4- speed) and a non-california smog car CWM (454 4-speed) car?
i mean...if they all came with smog...then why the cali designation?
Old Mar 15, 2008 | 06:00 AM
hunt4cleanair's Avatar
hunt4cleanair
Stricter emission requirements in CA than in other states which meant leaner mixtures and I suspect a different carb number. The pump permitted motors to run greater fuel ratios but still meet emission requirements. I show a part number 7044505 for a 454 with CWT. What is the number on your carb?
As model years rolled by, the emission requirements got stricter and four-speed motors had a harder time meeting the requirements until in 82...there were no four-speeds produced.
Both the auto and four-speed used the same emission certification ZJ (code) which is another indicator of power team configuration.
Old Mar 15, 2008 | 10:23 AM
ROBRICCI's Avatar
ROBRICCI
my carb is 7044221 - is this correct for a non california smog 4 speed car CWM?
thanks!
RR
Old Mar 15, 2008 | 10:52 AM
trw's Avatar
trw
thanks!
RR
That is a good number for your car.
Also the distributor was different for Cali cars. I'm sure it was to lean it down.
To 74 Big Block Smog Question
