Corvette 81 Wiring question
Old Mar 14, 2008 | 07:20 PM
pat80's Avatar
pat80
Default Corvette 81 Wiring question
I just install my new radio... I have the wiring diagram of the car.. but.. I still have two question..
The gray wire from the car is for what ?
The yellow wire from the car connect to the radio but one other yellow wire seen to go to the rear of the car ?
And, which wire take the antenna down, mine don't go down anymore...
Old Mar 14, 2008 | 07:31 PM
Iskenderian's Avatar
Iskenderian
The Antenna is usually blue (someone correct me if im wrong) The radio install in my 81 was diagram-less. Generally every radio has three power wires. Big yellow (On/off power) small yellow (constant power for presets/clock) and a ground (almost always black) Then an antenna/amp signal wire (usually blue). The radio wire will run back from the radio down under the center consol. Then all your speakers. I use an amp so those connections are not wired on mine. Hope this helps,
Bob
Old Mar 14, 2008 | 07:40 PM
pat80's Avatar
pat80
I have already install the radio... The 2 wire left are the one from the car...
Old Mar 14, 2008 | 10:51 PM
SIXFOOTER's Avatar
SIXFOOTER
This might help. Tow versions, with rear speakers and without
Gray wire is left front speaker
1 Yellow wire is the radio fuse hot only with key on. The other yellow is right rear speaker
Old Mar 15, 2008 | 08:04 AM
pat80's Avatar
pat80
the one on the left side, gray or brown... lps... ?
To Corvette 81 Wiring question
