Wiper door won't open???
Old Mar 14, 2008 | 09:14 PM
ENG40's Avatar
ENG40
Default Wiper door won't open???
The wiper door only opens and closes when the manual override **** is used, it will not open with the wiper switch. I've had the car completely torn apart except for the tach speedo panel and I think everything is hooked up properly now but could of missed something. I've got the AIM manual but it's pretty vague when it comes to the vac system.
Any thoughts?
Rick
Old Mar 14, 2008 | 09:47 PM
PeteZO6's Avatar
PeteZO6
There is a solenoid mounted to the tach that should operate when the wiper switch is turned on. When the solenoid operates, it closes the vacuum path to the actuator relay valve. The override that works on your car performs the same function. The override is located between the solenoid and the actuator valve. I would check the electrical wiring to the solenoid first.
Cheers,
Pete
