At idle, there is fuel dripping off the secondary venturies. So much fuel that the car floods and will not stay idling. You can actually see 2 to 3 drips per second dripping off each secondary venturi. What is the problem?
Has anything changed/occurred prior to this condition appearing?
Have you checked the float on the secondary bowl? Not knowing anything else, I would start there. pull the sight plug. If gas pours out, that is your problem. If that is the case, it could be the needle/seat gave out, fuel pressure increased too much, dirt lodged in seat, etc.
Good luck.
good questions/observation and thanks so much for chipping in. The only thing that changed was that I replaced the existing rubber fuel hoses w/ braided lines. Each time I've checked the fuel pressure, it has been a steady 7 lbs.
If you replaced the fuel line, the chances are very high that you have dirt lodged in your needle/seat assembly. The good news is that this is an an easy fix with the holley. You will only need to buy a bowl gasket and this will only take you an hour or two to clean or potentially replace depending upon age.
