Tach problem
Old Mar 15, 2008 | 08:06 PM
gbags's Avatar
gbags
Default Tach problem
My tach has not worked properly since I own the car May 07.
It appears to run backwards. When I am cruising it is pegged and when i am at idle it comes up some. Some one who did work for me told me the distribitor is in 180 degrees backwards.... I run the car and it runs fine. Could I have tuned it to run with the dist backwards.
Old Mar 15, 2008 | 08:10 PM
A88FXRS's Avatar
A88FXRS
bad printed circuit board in tach circuit.
Old Mar 16, 2008 | 09:14 AM
1Z87L8's Avatar
1Z87L8
what year is the car?
Old Mar 16, 2008 | 03:50 PM
gbags's Avatar
gbags
Default 78
it is a 78.
Old Mar 16, 2008 | 05:43 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Originally Posted by gbags
Some one who did work for me told me the distribitor is in 180 degrees backwards.... .
Don't let that guy touch your car.
Old Mar 16, 2008 | 06:53 PM
ACECO's Avatar
ACECO
St. Jude Donor '04 & '05
100%
Likely a bad circuit board. Many times when they indicate backwards it's a bad chip on the PCB. That chip is an obsolete part so if in fact it's bad, it may be difficult to repair w/o a donor board. You also could try an aftermarket replacement board, but many of those don't work properly either.
If you'd like more info on checking out your current PCB, please PM me.
Good Luck!
Old Mar 16, 2008 | 07:29 PM
65GGvert's Avatar
65GGvert
Let me know if you need a tach board that is pre-calibrated for a 78-79. I bought one and found a bad connection on the dash circuit board and never installed it. It comes with instructions and troubleshooting. I paid $75 plus shipping and I'll send it to you for $65 including shipping if you decide you need it. It's new in the box and never installed. It can be changed from the front without removing dash. If you aren't familiar with it and you need help, I'll include my phone number and talk you through it. Let me know.
Old Mar 16, 2008 | 09:09 PM
wombvette's Avatar
wombvette
NO NO, I would think the distributor is upside down. Thats got a be it.
Old Dec 14, 2008 | 12:19 PM
johnwiltfongjr's Avatar
johnwiltfongjr
7th Gear
I have done a bunch of reading about tach issues on here but now I have a question myself. I read about the filter that is attached to keep the circuit board from blowing due to voltage spikes. I have an accel distributor and it has 2 connections...one for bat and one for tach. I went looking and found a wire connected to the intake right in front of the distributer...it is yellow and looks like it would be connected to the distributor. On the tach wire that connects to the dist, there are 2 connections. Should that wire on the intake be connected to the dist or removed? Is it going to short out the board in the tach? Of interest is that when I go to start the car, the tach fluctuates and then pegs after it starts and is running.
Thanks for the help.
Old Dec 14, 2008 | 07:22 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
This more often than not is the problem
To Tach problem
