how do i adjust the brake pedal?
My .02.
so once that is established, replace the vacuum booster with a Hydroboost setup, and then the hydraulics settle down and all the air outta THAT sytem...leave it overnight just like power steering, the foam settles out of the oil n the reservoir, then it's all solid oil in the lines.....
you will IMMEDIATLY feel the car actually STOP for the first time in it's life.....shark will stand on it's NOSE and yours will go into the steering wheel....
2+ years ago, after a decades of being pissed at those brakes, I finally broke down and put in a HB system, pulled the m/cyl mount bolts loose, swung it forward on the lines without touching a THING in the brake system itself....put on the HB system, fired it up, and hit the brakes about 4-6 times, even with foam in the hydraulics....
that shark stopped on a dime with very little pedal travel, and when it grabbed, it grapped STRONG, none of the squishey mushey feeling to the pedal.....
you will have to learn how to remodulate the brakes all over again, the feel is total confidence , not indecision....
