Wheel backspacing on C3?
Old Mar 16, 2008 | 06:49 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default Wheel backspacing on C3?
I hope someone knows, Will a wheel with a 4.5 backspace fit a C3 (74) with out a prblem. The ones I want only come that way in a 15x8 unless I go custom.
Thanks Jim
Old Mar 16, 2008 | 06:56 PM
1981Z06Vette's Avatar
1981Z06Vette
I'm pretty sure that the stock 15x8 Ralleys are a 4" backspacing, so you should be fine. I'd take some measurements off of your existing wheel just to be safe, though.
Old Mar 16, 2008 | 07:03 PM
1982CorvetteDude's Avatar
1982CorvetteDude
I have 17" rims with a 4.5" BS and I had to move the parking brake bracket on top of the trailing arm because it hit the rim in the stock location.
I think you will at least have that issue for sure
Old Mar 16, 2008 | 09:17 PM
Rodbuster's Avatar
Rodbuster
I put 4-1/2 backspace on and had to run 1/2 inch spacers.
Old Mar 16, 2008 | 09:26 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Pull one of your rims, lay a bar across the back of the rim, measure from the back of the rim to the bar. You will now know what the rim backspace your running now is.
I run 4.5 BS on both our 72 & 79 Vettes, no issues, some years have different issues, some must remove the emerg. brake bracket to the top, some need wheel spacers, do the quick check of what you have now
Old Mar 16, 2008 | 09:37 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
It depends on what size tires you are using.. It also depends on your trailing arms etc..
I personally use 15 x 10 wheels with 4.5 inch backspacing with ET Drag 28 x 10.5W - 15 slicks.. However, my frame is modified for extra clearance and I'm using offset trailing arms..
Old Apr 22, 2008 | 08:05 PM
SpE3dF0x's Avatar
SpE3dF0x
This is a REALLY good point because I would like to know if 16 X 8's are acceptable without ANYmodification? But I know I'll need to do something about it. Any suggestions other than modifing my FRAME>?
Old Apr 23, 2008 | 07:09 AM
StickShiftCorvette's Avatar
StickShiftCorvette
I ran 15 x 8 wheels with 4" backspacing. I recall a stock aluminum 15 x 8 (later C3s) actually had 4.125" backspacing.
I currently run 17 x 8 wheels with absolutely no modifications. Either 245/45 or 255/40s fit well with no interfereces anywhere.
Old Apr 25, 2008 | 06:38 PM
SpE3dF0x's Avatar
SpE3dF0x
Thanks man! Printing this out!
To Wheel backspacing on C3?
