Checking Pushrod length
Old Mar 17, 2008 | 04:34 PM
Bowerss2's Avatar
Bowerss2
Default Checking Pushrod length
Does anyone know the best procedure for checking the best push rod length for roller rockers? Thanks,
Steve
Old Mar 17, 2008 | 04:48 PM
Scott Marzahl's Avatar
Scott Marzahl
Use a cheap plastic push rod length checker, no difference for roller or non roller rockers. You still want the same contact position/pattern.
Old Mar 18, 2008 | 09:29 AM
Surfer69's Avatar
Surfer69
If you use that you might need to take springs off and use "checker spring" on valves. Otherwise mark valve stem top with marker or crayon and use existing pushrod, rotate engine couple times and see what pattern looks like. Should be center to just outboard and about .05 thick. My .02
To Checking Pushrod length
