Hello folks thanks as always for your help, in advance!
I'm wondering if there is a stock replacement rotor that will interchange with the front. All dimensions the same except diameter. I am looking for a TRUE 12" rotor to swap in place of the 11.75" unit.
Long story, but my caliper and pad ride about 0.120" further out from center, so a 12" rotor would be perfect.
I don't know of a stock replacement rotor but www.colemanracing.com has 12" rotors and they can match a hat to work with it. They will be a bit more than a stock rotor but that is the only option I know of.
