Mystery Noise
Old Mar 19, 2008 | 10:41 AM
Bill Ehri's Avatar
Bill Ehri
Default Mystery Noise
My '74 with auto tranny has a noise that sounds like a lifter hanging up. The noise increases with rpm and load on the engine. I can usually activate the noise while the car is standing still by putting on the brake and running the rpms up to about 2500. The noise is less noticeable when the engine has warmed up.
Problem is, it's not coming from the engine but from under the car on the passenger side. I thought it might be the heat riser that was telegraphing back through the exhaust so I wired the riser open and it still made the noise. Natually, when I put the car on a lift it won't make the noise.
This has been going on for a long time. Last year the heads where completly rebuilt and the noise didn't go away.
Any ideas? Thanks, Bill
Old Mar 19, 2008 | 10:48 AM
jackson's Avatar
jackson
Exhaust leak sound often mimics tapping. Suggest you verify there's no leak at exhaust manifold/downpipe/header.
Old Mar 19, 2008 | 11:01 AM
BB68Vett's Avatar
BB68Vett
Old Mar 19, 2008 | 12:51 PM
goinbroke's Avatar
goinbroke
...and for whatever reason it's usually the rear exhaust port on the passenger side.
Old Mar 19, 2008 | 01:54 PM
gavanm01's Avatar
gavanm01
I concur. Had the same darn thing happen to me with the exhaust gasket letting go. Thought I had done something realllllly bad. Believe me, I found Jesus again until it was diagnosed. Still go to church and say a novina just for good measure...
Old Mar 19, 2008 | 05:38 PM
midlifemuscle's Avatar
midlifemuscle
Have you replaced the clutch recently?
Old Mar 20, 2008 | 10:09 AM
Bill Ehri's Avatar
Bill Ehri
Thanks for the comments, can not be the clutch since it's an automatic but I'll check the exhaust system. Bill
Old Mar 20, 2008 | 10:29 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Bill, why don't you take a few minutes and fill out your profile. This will help Forum members help you.
Old Mar 21, 2008 | 11:08 PM
Bill Ehri's Avatar
Bill Ehri
Good idea, it's done.
To Mystery Noise
