68 Big Block Differential ID ?
Old Mar 19, 2008 | 11:41 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default 68 Big Block Differential ID ?
How can you tell if the differential on a 68 Corvette is for the 427 cu in engines? Also, where are the ID numbers located?
Old Mar 19, 2008 | 11:57 AM
Binnie77's Avatar
Binnie77
The code will be stamped in bottom flange. There were several codes used for 427s. Here are the codes:
http://corvettec3.ca/axle.htm#1968_Options
Old Mar 19, 2008 | 12:04 PM
GTR1999's Avatar
GTR1999
Other then the HD side yokes there's no difference to them except the stamping.
Old Mar 19, 2008 | 12:12 PM
pmihaltian's Avatar
pmihaltian
Slingshot
What do the HD side yokes look like? Also, by the bottom flange, do you mean where the drive shaft comes into the jackpot?
Old Mar 19, 2008 | 12:13 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Thank you Binnie.
Old Mar 19, 2008 | 12:16 PM
stinger12's Avatar
stinger12
The HD side yokes have bolt on caps for the u-joints. The small block vettes had straps that went on top of the u-joint cap and were held with two nuts at the back of the yoke.
Old Mar 19, 2008 | 12:29 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Thank you.
Old Mar 19, 2008 | 12:41 PM
langg's Avatar
langg
Do bolt-on caps always mean HD yokes? My 75 has bolt-ons and it is the low perf engine.
Old Mar 19, 2008 | 01:27 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Unless I've missed it, your '75 has the HD yokes. Apparently that was the last year they were available. There may have been a production line change after the diff was in, or maybe they just used up the parts which were being phased out and you got lucky.
Old Mar 19, 2008 | 02:44 PM
GTR1999's Avatar
GTR1999
The HD yokes were used on BB, SHP SB's as well as base motor automatics. So just about everything except for the base motor 4 spd's.
My original 72 350-200 TH400 has them.
Old Mar 20, 2008 | 01:28 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Click photo to enlarge
I came across this photo which may be useful to some folks for identification purposes.
Old Mar 20, 2008 | 03:36 AM
TheSkunkWorks
I did not know that. I would have thought base motor autos should have had the std yokes if any applications did, but then Gary's the diff guru here, not me...
Old Mar 20, 2008 | 02:24 PM
lr172's Avatar
lr172
I am looking to beef up the rear end on my '75 and mine has the straps. Does anyone know where to obtain the stronger caps? Also, does the main driveshaft and u-joints need attention as well?
Old Mar 20, 2008 | 03:18 PM
GTR1999's Avatar
GTR1999
caps are expensive these days look at any vendors catalog and they run $40 EACH. Some have used the aftermarket caps as well. You're going to need more then yokes to beef up the diff.
Old Mar 21, 2008 | 02:43 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Mid-America's latest catelog has them listed.
To 68 Big Block Differential ID ?
