Need help with lower ball joints
Old Mar 19, 2008 | 08:53 PM
Erik016's Avatar
Erik016
Default Need help with lower ball joints
I don't know if it's been a long day or I just can't think right now. I've been trying everything to get my lower ball joints in but nothing works. I measured it and it's the correct size. Top one went in real easy. Any help would be greatly appreciated.
Old Mar 19, 2008 | 08:58 PM
Durango_Boy's Avatar
Durango_Boy
I think you have your lower A-arm on upside down. The ball joint should point DOWN, and the bore in the knuckle comes UP onto it. The shaft of the ball joint is tapered, and you're basically trying to put it into the wrong end of the hole.
Also, the coil spring needs to be installed right before you do the ball joints or you'll never be able to get it in.
Old Mar 19, 2008 | 09:00 PM
Erik016's Avatar
Erik016
lol . I just noticed my paper was upsidedown to . Thanks for the info. I'm fixing it now.
Old Mar 19, 2008 | 09:30 PM
mrvette's Avatar
mrvette
Damnit man, just DAMNIT, you gotta know which way the taper for your stem fits in the hole....
Old Mar 20, 2008 | 10:29 AM
ikwhite's Avatar
ikwhite
Durango _boy think he might have a hard time finding coil springs for those aftermarket VBP tube A Arms though. I had to laugh when I saw the arm upside down as I went to do the same thing about a week ago, had to stop and think for a sec.
Old Mar 20, 2008 | 11:00 AM
Durango_Boy
I know they didn't look stock, but I didn't realize they didn't use coil springs...if that's what you meant.
Old Mar 20, 2008 | 01:46 PM
Erik016's Avatar
Erik016
Finally finished the whole front end yesterday. Thanks for the help darango_boy. Everything looks good but I still go to move the transverse spring towards the passenger side about a 1/4 inch because it looks off. I also forgot to mention that it was a mono when you
advised me about the coils. I'll post pics later.
Old Mar 20, 2008 | 03:47 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
I think you have other problems. The whole a-arm is upside down. Swap the arms right to left.
Old Mar 20, 2008 | 11:18 PM
ikwhite's Avatar
ikwhite
I only knew because I have a set, they come with the mono spring kit as was mentioned later.
To Need help with lower ball joints
