Erson cam help
Old Mar 19, 2008 | 09:54 PM
rponfick's Avatar
rponfick
Default Erson cam help
I am trying to find out some information on an Erson cam after tearing down my '73 big block. The cam has a nice lope to it and runs great, but have been unable to find out any specs on it. There is some rocker arm and lifter wear so I don't plan to re-use it.
Information on end of cam reads: Erson, Hi Flow 2H, 791 and J 1 or 3 1. I would like to duplicate it's specs but have not been able to find any info. I understood Mr. Gasket acquired them a while back, but they now say they haven't owned them for over a year now. Nothing comes up on a Google search as to how to contact them now.
Anybody know anything about this cam or how to contact Erson?
Ralph.
Old Mar 19, 2008 | 10:07 PM
Ironcross's Avatar
Ironcross
he started on his own after working with Ed Iskenderian, as a resulr you will probably find the same grinds.
BritewhiteC3's Avatar
BritewhiteC3
found this on an old "hotrodders.com forum, it's dated Oct 07
#5 10-11-2007, 05:45 AM
AHotRod
Member Join Date: Jan 2002
Wiki Edits: 0
re: erson cam who sells them
Erson Cams was sold off by Mr.Gasket earlier this year to PBM in Louisville, Ky.
which is a Auto Parts Warehouse.
Here is the contact information: PBM Performance Products: 1-800-588-9608
Good Luck
Old Mar 19, 2008 | 11:11 PM
speedreed8's Avatar
speedreed8
http://go.mrgasket.com/pdf/ERSON.pdf
try page 26-30 big block chev.
Old Mar 20, 2008 | 08:34 AM
jnb5101's Avatar
jnb5101
i've got an erson in my sb. info card gives 550 Mallory Way, carson city, nevada 89701, 702-882-1622. info is about 2 years old.
jeff
Old Mar 20, 2008 | 09:34 AM
GOSFAST's Avatar
GOSFAST
Default Erson Cams
Used a few of that grind on some BB builds here back in the mid/late
'80's.
Decent cam back then, some of the "older" grinds still deliver in today's setups.
Just used a solid/flat-tappet "Engle" from 1970 (this was an NOS cam still in the box from that year) in a 396" BB "pump-gasser" and made 500+ HP on 93.
Regardless of all the "hype" on "new/up-to-date" cam grinds, DO NOT cut the "old" ones short, they WILL deliver!!! This is especially true for today's "drivers", not where HP is being "chased"!
In any event, the spec's for your's is.....
cam part#120521, 235* @ .050" x .542" x (110* ICL). The ICL is where we installed these cams. I don't have the original cam cards showing the L/S or the (recommended) ICL, only on our job tickets! Installing at the 110* gave the best power!
Thanks, Gary in N.Y.
P.S. We often spoke with T-***** (?) down at Erson back then, not sure about the entire operation today!
To Erson cam help
