Carb vacuum ports
1. Distributor TVS
2. Fuel Vapor Cannister
3. Air Pump Diverter valve
4. PCV/Fuel Vapor Cannister
5. EGR TVS
6. ?
7. Brake Booster
8. Temp Switch on the air cleaner assembly
I have the following info to help me route this, but I think I have more ports than are needed.
Also, I purchased a used air cleaner assembly from an '81. There is a tube off the drivers side that I don't know what it connects to. (It's numbered 8 but should be 9)
#6 can be capped off as it isn't used/located on a 1980 Quardrajet.
Missing on the top front of the quadrajet is the bowl vent line that goes to the cannister. You can see the undrilled boss for it just right of #3 and just above the blue TVS. It was used to vent the fuel vapor fron the fuel bowl back to the cannister on later year carbs.
