Brake Bleeding
Old Mar 22, 2008 | 09:25 AM
Yeller81USNRet's Avatar
Yeller81USNRet
Default Brake Bleeding
When you bleed the brakes do you need the engine running or is it done with the engine off.
Durn it forget.
Damned Old Age
Ken
Durango_Boy's Avatar
Durango_Boy
Durn it forget.
Damned Old Age
Ken
Engine off.
Old Mar 22, 2008 | 09:27 AM
Yeller81USNRet
Thanks that was quick
Wowzers
Old Mar 22, 2008 | 10:18 AM
Durango_Boy
Wowzers
You're welcome. Good luck.
Old Mar 22, 2008 | 10:56 AM
Yeller81USNRet
I got good brakes just want to freshen up the fluid ...
Been in there a long time
Ken
Old Mar 22, 2008 | 11:23 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yep, about every 2 years is the general rule for flushing.
Old Mar 22, 2008 | 11:08 PM
s79vette's Avatar
s79vette
one day a few years ago I was thinking about making brake job easier.
Went to local farm store and got a 1 gallon spray jug and made a 1/4 inch thick steel plate to cover master cylinder. glued a rubber gasket to one side and drilled 2 holes in it, drilled and tapped for 1/4 inch hose to pipe fitting. Hooked hoses to a pipe T and attached to jug. I also added a
pressure gage. Now I can pump up to a few pounds pressure and bleed
each brake line with no drips and no errors. It might have cost me 10
bucks total. Something for you to do on a lazy day. I hold it on with a C-clamp. Steve
Old Mar 22, 2008 | 11:34 PM
spedaleden's Avatar
spedaleden
I just used speed bleeders, these things are great!
To Brake Bleeding
