Steering Shaft Rack and pinion conversion question
I have another rack and pinion conversion question. I hung my rack and set up the steering linkage and noticed that there is a bit of play in the steering wheel due to side to side and up and down movement of the steering shaft coming through the firewall, it appears the bearing where it exits the firewall is pretty wore out, considering I have 222,000 miles on my 81 this should be no surprise. So it appears that the shaft would rather move side to side before it turns creating slop in the steering wheel. Has anybody else experienced this? I would hope that when this arduous and expensive project is over I will have very tight steering?
I appreciate the help.
but if you doing a kit like Steeroids, maybe you need to be concerned, I honestly dunno....they use 3 universal joints, I only used two...
