will this serp setup work?
Old Mar 25, 2008 | 03:52 PM
Sully1882's Avatar
Sully1882
Default will this serp setup work?
I have a line on a 89 chevy silverado with a TBI 305CI V8. I can get the whole serp setup and accessories from the truck for just about nothing.... maybe $80. Will this work for my original 1972 Smallblock??? Any help would be great! Thanks in advance!
Sully
Old Mar 25, 2008 | 04:15 PM
markdtn's Avatar
markdtn
yes, there are several of these running. Do a search.
Old Mar 25, 2008 | 04:18 PM
Sully1882's Avatar
Sully1882
I know I have seen a number of guys running the serp setup from the 350 TBI version but I wasn't too sure about the 305 version... if it was compatible and the same ole story! I'm glad to hear that! Guess I will go and get it!
Thanks,
Sully
Old Mar 25, 2008 | 04:26 PM
SIXFOOTER's Avatar
SIXFOOTER
I have one of those setups and it didn't look like the hood would close, so I got one from an 88 vette
Old Mar 25, 2008 | 04:29 PM
Sully1882's Avatar
Sully1882
was it b/c of the A/c compressor or the alt? Did you try it or just eyeball it? I don't doubt you b/c you almost always have great advice but I just need to know for sure...
thanks,
Sully
Old Mar 25, 2008 | 05:23 PM
Artsvette73's Avatar
Artsvette73
thanks,
Sully
The truck serp. seems to sit high in the front. Alt and comp. I did my 73 with one off a S10 4.3. I cant say for sure that the stock hood would fit. I have an L88 aftermarket hood on, and never put the stock on to see if it would fit. I kinda doubt it.
Old Mar 25, 2008 | 07:19 PM
SIXFOOTER's Avatar
SIXFOOTER
thanks,
Sully
I was eyeballing because I don't have the front clip back on it yet, but it looked pretty high, above the top of the radiator support. I got it pretty cheap and got a decent deal on the 88 vette setup so the truck setup went in the spares box
The top of the R4 compressor was going to be a problem.
Old Mar 25, 2008 | 07:34 PM
Durango_Boy's Avatar
Durango_Boy
Sully
Is this the same as the LT1 brackets you asked me about or a different deal altogether?
Old Mar 25, 2008 | 10:01 PM
Sully1882's Avatar
Sully1882
diff deal all around.... i can get a whole LT1 set up or I can get this serp setup off this silverado truck. I know that you said the Lt1 stuff won't fit b/c of the A-arms. I'm just wondering if this late 80's 305 silverado setup will fit...
Sully
Old Mar 25, 2008 | 10:44 PM
markdtn's Avatar
markdtn
You can't use LT1 stuff on a "regular" small block. LT1 has the water pump driven off the cam. TBI truck stuff 305, 350, even some 4.3 is all the same; there are several who have used it successfully.
Old Mar 25, 2008 | 10:54 PM
Sully1882's Avatar
Sully1882
think so?? I thought so too when looking at it but everyone else seems to think it wont fit under my stock 72 hood... you have an early C3 like mine, Mark, you'd know best... should I try it or keep looking for a early C4 setup???
Sully
Old Mar 25, 2008 | 11:03 PM
markdtn's Avatar
markdtn
Sully
Just for the record, I have a C4 setup on mine and it fits fine. I have said in the past that TBI stuff looked high and had a long water pump that wouldn't work but I got pictures shown of people that had them in the car and running. I can't say for sure because I have not done it or seen it with my own eyes but I have seen pictures posted here. I'll try to find one.
Old Mar 25, 2008 | 11:12 PM
Sully1882's Avatar
Sully1882
Default thanks Mark
I appreciate your help! Let me know what you find... I would really like to speak with someone who has done this firsthand... Yeah I know you have a C4 setup and it looks just awesome... I really like the way it looks overall...plus you do have it in a pretty lil steel bumper early C3... I'm kinda partial to those too.
Old Mar 25, 2008 | 11:29 PM
markdtn's Avatar
markdtn
I can't find anything in the last year-sorry. I know you cannot use TPI with TBI brackets, but I was pretty sure I have seen more than 1 photo of somebody with tbi truck or 4.3 brackets in a carbed C3 with stock hood. Can't find the proof-anyone?
Old Mar 26, 2008 | 05:25 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I've got the F-body setup, and I wouldn't want the alternator and A/C pulley sitting any higher. Those truck brackets are tall...
Old Mar 26, 2008 | 07:53 AM
Durango_Boy
Mark, can you give me some measurements from your car please? First, I need a measurement of how high the front tip of your air cleaner is from the front intake seal deck. Then, please lay a long straight board or rod from the tip of the air cleaner to the top of the radiator core support. Take pics from the side showing clearance under that board. Then, please measure from that board, straight down to the center of the crank pulley.
I can use these measurements to determine, based on the air cleaner Sully has, how much room he'll have with his stock hood to fit the TBI brackets.
Pics from the side with that board will really help a lot. Thanks.
Old Mar 26, 2008 | 11:26 AM
Sully1882's Avatar
Sully1882
man, I'm confused....surely someone has tried a truck serp setup with a stock early C3 hood...
To will this serp setup work?
Old Mar 26, 2008 | 11:34 AM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
As soon as you guys figure it all out, let me know. I want to install a cost effective serpentine soultion on my project Vette. And from what I've seen/priced so far, this kind of mod is costly unless you can find the "ideal" setup at a junk yard.
Old Mar 26, 2008 | 11:42 AM
SIXFOOTER's Avatar
SIXFOOTER
Yea, if y'all figure it out I'll have one for sale
Old Mar 27, 2008 | 04:18 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Define "cost effective" - my F-body brackets cost less than $200, then I had to buy a few things like an A/C delete pulley and the proper water pump.
